Question about LG 47LF11 LCD TV
I have a 47 lg lcd tv bought in 09. When i use hdmi for xbox 360 i get picture and sound but with ps3 no pic no sound. I just bought a sony bluray and get pic but no sound. I bought a lg bluray and get no pic no sound. I have tried 2 or 3 different types of hdmi cables but nothing so far has given me sound and picture...help please.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 9 Answers
To clarify, your TV is working correctly, since you get sound and video from all devices - Only your PS3 has no sound or video?
If your PS3 was previously used with regular AV cables (Red/White/Yellow) then you most likely need to do a PS3 video reset t output video over HDMI.
With the PS3 OFF, press and continue holding the power button until it turns on, beeps twice, and then turns back off. Do not release the power button during this process.
You may have to try the video reset a few times if it doesn't work right away.
After video reset, you should get sound and video over HDMI.
Posted on Nov 15, 2017
5 Suggested Answers
Anonymous
SOURCE: LG 47" LCD TV - 47LC7DF Clicking Noise
I was told that these clicking noises (which happen on my Magnavox LCD too) were due to the "power required" at the internal switch. Seems that the power required to immediately turn on the TV is too much for a standalone household outlet, so it "surges" power in a series to get enough there. Hence, the clicking sounds are actually mini power surges to send more power to the internal circuits to turn the TV on.
If your set is like mine, these noises generally stop after a minute or two, correct?
Posted on Mar 29, 2008
Anonymous
SOURCE: compatibility ps3 lg rz32lz50 tv
Sounds like your DVI converter. DVI provides picture only, no sound. If your TV has an digital optical input socket, it's best to connect PS3 to TV using this, then digital stereo sound should be yours..
Posted on Nov 26, 2008
Anonymous
  • 60 Answers
SOURCE: "No Signal" for PS3 using HDMI cable
jareddirk30:
you didn't mention what software version your ps3 is. in this digital age it's important to keep software levels up to date, with some exceptions. i'm including the web address for sony so you can update the ps3, but i don't think it's the problem. once you're are on their site you click on the ps3 picture & that link will take you to the software update pg. there you can review previous software updates. i quickly reviewed 1 of those & didn't see anything that addresses your problem.
http://www.us.playstation.com/Support/SystemUpdates
have you verified that the HDMI inputs are are enabled correctly? thereare 4 inputs. refer to pgs 25 & 26 of the owner's manual.
I would put the heat on your LG retailer. clearly the new main board is suspect. you had the functions prior to the swap. the board is probably defective, but with a different problem than what you had previously. i visited LG's site. they currently have nothing in their knowledge base that mentions the your problem, nor is there a software update.
if you need additional help. write back. good luck.
peace-out
Posted on Feb 11, 2009
Anonymous
  • 19 Answers
SOURCE: LG 42LG5 hdmi not working
Have you tried another HDMI cable? The cable may be bad. However, if this is not the case and this is happening across mutliple devices(cable box, dvd player, etc) then you might have a bad HDMI input on your TV. Does this happen on all HDMI inputs on your TV? If you can safely rule out your other devices and the cable itself then you've got a main board problem and would need to get it replaced.
Posted on Feb 21, 2009
Anonymous
  • 121 Answers
SOURCE: ps3 wont work on lg tv with hdmi cable
With the PS3 and the TV properly connected and both units off turn on the TV and set the input to the proper HDMI setting then press and hold the power on button on the PS3 until it beeps twice. This should resolve your issue. Please let me know how it works for you.
Posted on Feb 26, 2009
I have a LG LCD TV 26LX2R and I recently bought a Sony Blu-Ray BCP-S580. If i connect them via Composite or Component cables i get ok video and audio. But when i connect them via HDMI i get excellent image...
I can't speak on whether or not the apple tv has such a setting but the Bluray players does. You go into the bluray player's settings and change the audio output.Your choices should be 2 ch possibly hdmi, bitstream, pcm, and auto. Try hdmi, 2 ch, and pcm because if you have it on auto you might not get sound via an hdmi cable and it's probably not bitstream but try bitstream if none of the others work.
Sep 20, 2011 | LG 26LX2R 26 in. HD-Ready LCD TV
Xbox 360 working thru HDMI working fine. Now no sound & weird pic
it is prolly an internal problem. have to tried connecting the componet cables?
Mar 03, 2010 | Microsoft Xbox 360 Console
BRAND NEW 42in. vizio 1080 LCD HD 120HZ picture not clear
the tv models in store are usually have samples from blueray dvds. standard dvd players will look fuzzy because it only submits standard dvd picture quality. you can try an upvert dvd player. tho i cant promise picture quality. i have an xbox 360 that upverts the quality. if you get a bluray player i recommend hdmi wires. if you get upvert dvd player and it has an hd outlet red, blue, green wires it might work. i havent tried one myself. if you dont want to spend money on bluray dvds. i recommend an xbox console. it upverts dvds through hdmi or hd red, blue, green wires
Aug 26, 2009 | Vizio VW32L 32 in. LCD HDTV
PS3 setup to Denon AVR 2807 & Samsung LCD
Azahid
Since you are running the to LCD monitor instead of a LCD TV this is where you run into the issue. because the monitor is not setup to pull out the audio from the HDMI connection. So there is a few ways that you maybe able to to this.
The first one is look around at the different output cables out there the PS3. (I just got one so I do not know the accessories that are out for the PS3) This is becoming a common setup so if Sony does not have cable that will split off the audio then a 3rd party group may. I know they have one like that for the XBOX 360.
Another you can try is if your monitor will except an analog connection you may need to go that way. That is how I have my XBOX 360 that is my room connected. I have a RBG HD to VGA connect the VGA input on the monitor and the audio going to my sound card.
The reason why I suggested going analog is that right with our curent technology that if you are run with the 2 formats at the same time you will get audio/video sync issues. So you need to go all analog or all digital.
I hope this helps. Let me know if you have any other questions on this and/or need me to clarify anything.
Issken
Sep 29, 2008 | Sony Playstation 3 (PS3) Console
Compatibility ps3 lg rz32lz50 tv
Sep 06, 2008 | LG RZ32LZ50 32 in. LCD Television
Major problems with PS3 and viewing Bluray movies
did you uncheek the other options when choseing 1080p or it might be your receiver because you have to set that to make the picture quality as much as the ps3
May 19, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3 problem
press and hold power until you hear a beep sound
May 12, 2008 | Sony Playstation 3 (PS3) Console
No sound through ps3 hdmi
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
LG 47LF11 LCD TV Logo
Ekse
RONALD CARTER JR
