SOURCE: I need a diagram for serpentine belt replacement on a 1999 For Escort ZX2
the diagram is located in the engine compartment under the hood.
Clean off the surfaces and it is one of the stickers there.
SOURCE: where is the ac low pressure port to recharge the
It is on or near the reciever dryer or shiny looking thing at the right rear of the engine compartment. You need gauges to correctly add refigerant as you can overcharge it.
SOURCE: how can I add freon to 1999 chev lumina
Get an a/c charging kit, it comes with a can of freon usually with a blue hose, and a small guage on it. The type is R134a.
Under the hood look for the a/c pipes, one has a red cap which is the high pressure, and the other has a blue cap,( that can be anywhere), that's the you need. Unscrew the cap, screw the blue hose on to the pipe, DO NOT TURN CAN UPSIDE DOWN. Start engine, turn on a/c full blast, open valve on can. Shake once in a while. When can is empty disconnect. If no other problems with system, there should be cool air coming out.
