Cars & Trucks Logo
Posted on Mar 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Code for mercedes vito 108tdi van requesting radio code
Anonymous
Level 3:
  • Master 3,400 Answers
  • Posted on Mar 14, 2011
Anonymous
Master
Level 3:
Answers
3400
Questions
Helped
985085
Points
10767
You need to contact Mercedes dealer & provide VIN# to get security code for your radio
1helpful
My vitto 115 electrics does not work after charging the battery
Try the Benz Forums. Sounds like overcharge spike.
Vito 115 electrical Gremlins ' Mercedes-Benz Owners' Forums
https://forums.mercedesclub.org.uk > vito-115-electrica...
Jan 20, 2014 - My 639 115 vito that I've had almost 3 year and been totally reliable has suddenly started playing up. I parked it up for a couple of months ...
no power vito 115 ' Mercedes-Benz Owners' Forums
May 28, 2006
Merc Vito electrical issue ' Mercedes-Benz Owners' Forums
Jul 26, 2018
Vito 115 CDI COMPACT SWB indicators and wipers not ...
Nov 6, 2020
Vito 115- start probs?!! ' Mercedes-Benz Owners' Forums
Mar 3, 2008
More results from forums.mercedesclub.org.uk
vito 115 tow bar electrics ' Mercedes-Benz Forum - BenzWorld
https://www.benzworld.org > ... > V-Class
Aug 30, 2019 - Hello everyone, I'm just about to swap my 108d for a 06 115. I need to fit a tow bar and twin electrics to the new van. Does anyone have experience of...
Vito 2004 wiring diagram ? ' Mercedes-Benz Forum
Jan 8, 2017
Vito 115cdi 2006 electric windows removal - BenzWorld
Dec 24, 2010
Vito 112 CDI Electric Windows ' Mercedes-Benz Forum
Mar 22, 2011
Vito 115CDI Won't Crank/Start - ECU fault?! - Please advise...
Jun 14, 2012
More results from www.benzworld.org
buy Electric parts for Mercedes-benz Vito bus (w639) 115 CDI in our ...
https://allparts.me > mercedes-benz > electric parts
Take a look at our selection of Electric parts parts for Mercedes-benz Vito bus (w639) 115 CDI. We provide a guarantee so that you can order with confidence ...
1helpful
I have a Mercedes vito with fault code p2123. I drove the van under quite heavy acceleration ad it has cut out and now won't start?
First check connections to see if any corrosion . Then use a code reader see what all codes pull up (write down) then clear them out and see what happens .
Merc vito 2001 engine goes into limp mode but resets when turned off
The first thing that need to be done here is to have the fault code(s) read that are recorded in the computer's memory (PCM) when this happens. Do not keep driving the car or you will damage the engine and/or the transmission.
Key fob will not connect with ignition on Mercedes Vito 115 2008
More likely than not, you have the famous broken solder joint(s) at the coil inside the FOB...if that is fine and all solder joints look fine , then you had best get MB, or a good Mercedes Independant garage, to check the EIS and make sure it sees the key
How to fix a lower steering column universal joint on a 1998 mercedes vito van
For safety reasons that part must be completely replaced, not fixed.
I have a 2002 mecedes vito 110 cdi and i need to
just take it to auto zone or advance auto and they will do it for u for free
7helpful
4answers
2helpful
2answers
2helpful
Top Mercedes-Benz Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
xxxxxx xxx
Are you a Mercedes-Benz Expert? Answer questions, earn points and help others
