2005 Suzuki Boulevard C50 Logo
Posted on Mar 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Speedometer and odometer not working , harness is ok and checked fuses and seem to be ok
BJ Russell
Level 2:
Sergeant:
Champion:
  • Expert 214 Answers
  • Posted on Sep 12, 2012
BJ Russell
Expert
Level 2:
Sergeant:
Champion:
Answers
214
Questions
Helped
55791
Points
508
The Speedometer has been known to go bad. But if you check the SIGNAL fuse in the fuse block behind the left rear engine cover you may find it open. Replacing the 10 amp fuse should get it working again. Don't just measure the fuse's voltage test points, pull it and look at the fuse itself.
What , odometer, cause the radio, speedometer, power mirrors,power locks,all to stop working at the same time. I checked all the fuses yesterday and they were ok.
What make , model and year vehicle . And what are you asking here ? What , odometer, cause the radio, speedometer, power What would cause these to stop working or could the odometer cause these to stop working ? It would depend on what controls them . A BCM - body control module ?
2answers
Speedometer and odometer have stopped working. I have replaced the VSS and they still do not work
suspect you may have some sort of power issue. Check all fuses. May be a hairline crack in a fuse that powers the speedometer. If you can get a 12v light prove place negative of probe on car body and then put the probe pointy end on each side of each fuse to test each fuse .
google 12v probe.
http://www.supercheapauto.com.au/online-store/products/Toledo-Circuit-Tester-Heavy-Duty-6V-12V-24V.aspx?pid=305190#Recommendations
Stereo windshield wipers clock and speedometer odometer not working on 1993 altima nissan
if everything works when you jiggle the ignition... then its the ign switch try to see if wire harness plug is loose... if not have ign. switch tested then replaced..
2003 ford taurus installed aftermarket cd player in my car and accidentally grounded the poet wire out and now I have no power windows, no wiper blades, no radio, no speedometer, odometer, or hazzard...
dont b a **** fool and cut wires under your dash for some boom booms in your car buy the connecting harness they sell theres one for every make and model out there solves guessing and saves headaches... dont be a ******* buy the right parts
1helpful
Broke speedometer and odometer reader
you may need a car electrician as these things need troubleshooting.the only thing you can do is by checking all fuses however if other gauges and indicator lights are working then the fuse for the inst. cluster is ok.the speedometer has a sensor installed on the transmission while the odometer gets signal from the ECU so these two problems need separate solution
2answers
Speedo, odometer and fuel gauge don't work
You probably have a sporadic fuse failure - go in and replace the fuses linked to these functions with NEW fuses and make sure there is no corrosion on the fuse box connections - this should solve.
4helpful
1991 Dodge Daytona Speedometer and Odometer not working.
I had the same problem with my 90 daytona. The tach and the speedometer would work intermitantly. I took the whole gauge cluster out, and heated all the soldering with a solder gun to reflow the connections. It seems that this is a common problem with the connections cracking. You may not be able to see the cracks in the solder.
6helpful
Speedometer/ Fuel Gauge & Tachometer not working
check for loose connection at the instrument cluster.
Top Suzuki Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Bob G
Are you a Suzuki Expert? Answer questions, earn points and help others
