SOURCE: connection to my faucet
There is an adapter that you can buy at most home improvement or hardware stores. If you can't find it locally you could also try sears.com for the part.
SOURCE: faucet solution for hooking up portable dishwasher
there is a generic adaptor that fits on your faucet; take the name, model# and, hose to a hardware store and, they can show you the right adaptor for your machine
SOURCE: why wont dishwasher drain?
The 'drain hose' must placed into the sink and be free of kinks and obstruction. There is a pump that is supposed to pump the water out through the drain hose into the sink. If that pump does not activate, no water will be pumped out. I suggest yo have a repair technician trouble shoot and fit it.
SOURCE: asko dw 95.2 model 1705 after 6 years of use the
Check the level and tightness of the slide rails--they may have come loose after the years of use. Make sure the dishwasher case itself is level. Hope this helps!
Testimonial: "Thank-you. The unit is perfectly level. The rails are spot welded and all bearing seems to be OK. Nothing to tighten, will investigate further now that I see the system is not complex at all. Thanks for replying so quickly. k"
SOURCE: Water does not drain completely,water from sink backs up in DW
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
