In Windows your security settings need to be set to accommodating this installation you can find the security settings for IE8 by going to tools then internet options set your security to low from your question it reads that you have done this already my research bring me to this option please read below.
Article Applies To:
SonicWALL SMB SSL-VPN Appliances and Software: SMB SSL-VPN 2000, SMB SSL-VPN 4000, NetExtender
Firmware/Software Version: 2.5 or higher
Problem Definition:
When installing NetExtender on any supported Windows operating system, the error "Failed to install NetExtender, the installation has been rolled back" may be observed, especially when the operating system is installed on a drive other than the default. This issue is resolved by upgrading the SSL VPN 2000 or 4000 appliance to firmware version 2.5 or higher and making another installation attempt.
Resolution or Workaround:
For each of the following possible causes of this behavior, an explanation, workaround, or solution is provided:
Source: SSL VPN 2000/4000 2.5 Release Notes this has been copied from doing my research this is not my material but a help post from another source. Thanks for using FixYa! do not forget to vote for me. John
Cisco VPN Client for Windows Vista, release 5.0.0.340, does not support the following:
•Microsoft Windows NT, 98, and ME.
•System upgraded from Windows XP or earlier Windows operating systems to Vista. (Clean OS installation required.)
•Combination of Cisco Unified Video Advantage 2.1.2 and McAfee HIPS Patch 4 Build 688. To avoid system failures, uninstall either of these two applications, upgrade McAfee to the latest version, or use VPN Client 4.6.x.
•Translated Online Help. Online Help is provided only in English.
•64-bit Windows operating systems. For x-64 support, customers should explore with their Cisco sales representative the use of the next-generation Cisco AnyConnect VPN Client.
