Question about Fujitsu Siemens Computers & Internet
Hi! my pa 3553 monitor is just blank when i switch on the laptop. i tried inserting the repair disk but couldn't do anything since i cannot see anything on the screen. this is the first time i'm having this problem, i've been using the laptop for just over a year. cheers!
Posted by ladioluwa on
5 Related Answers
Benimur
Louie Role
  • 6966 Answers
SOURCE: problem monitor
Hi, Sounds either a backlight problem (inverter or tube light) or the display interface. Since you have confirmed that it is your LCD monitor, your best bet perhaps is to seek the services of a qualified professional. Should you venture in doing it yourself (DIY), You need to open up the casing. A step by step procedure is better illustrated here . The working principles of notebook/laptop displays are nearly identical to your LCD. Hope this be of some help. Post back how things turned up or should you need further information. Good luck and kind regards.
Posted on Sep 26, 2007
Anonymous
  • 579 Answers
SOURCE: Monitor displays breifly then goes to blank screen
The green power light indicates that the monitor is receiving from the computer correctly. I suspect it is going into high voltage shutdown. There is a safety circuit that monitors the high voltage and shuts the monitor down if it sees anything amiss. So the monitor comes on and then shuts off. High voltage problems are generally not worth trying to repair. Another example of a worthless safety feature. High voltage failures are not dangerous, and adding the safety circuit just kills the unit when it may have some life left or worse, sometimes it is the shutdown circuit itself which fails!
Hope this helps.
Posted on Jan 10, 2008
Anonymous
SOURCE: Blank Laptop Screen
sorry about posting for trouble.
similar blank screen problem with Toshiba satlite notebook but I can see the desktop with no light from lcd. so if you just see the screen it's black untill you see very close to the monitor. When it boots i can see the normal screen and it goes away blank. Any suggestion?
Posted on Mar 31, 2008
shaggyrat
Christophe Thompson
  • 1224 Answers
SOURCE: problem with the samtron 45bn monitor
sounds like your video card went out simple check of this
if you have another computer that works hook it up to its computer if screen comes on it will be your video card in the comp now if the screen still doesnt work it will be the cable the pins in the end has some how bent or come loose this will require a service tech electrician to repair simple quick job
Posted on May 26, 2008
Anonymous
  • 40 Answers
SOURCE: Screen So Bright I Can Barely See Anything...
The auto dimming circuit on the ccfl inverter is out.  Replace the inverter and it should cure your problem.  Seek adult supervision for this repair. Do not try it by yourself.
srich
Posted on May 27, 2008
Where can you find the CMOS battery for Fujitsu Siemens Amilo PI3625
On the web!
Fuijitsu Siemens Amilo Xa 2528 CMOS Batterie - YouTube
? 6:39
www.youtube.com/watch?v=s8kKHChQ2sw
Oct 16, 2013 - Uploaded by MrHarsel Fuijitsu Siemens Amilo Xa 2528 CMOS Batterie ... Fujitsu-Siemens Amilo Pa 3553 - Disassembly and fan cleaning - Duration: 16:09. by ...
Sep 25, 2015 | Fujitsu Computers & Internet
My amino notebook pa 3553 can turn on but no display nothin comes when u turn on
Hello!
Please turn off power.
Please unplug from power.
Remove battery.
Plug in power.
Turn on power.
If computer works please replace and dispose of battery promptly and properly.
DANGER: Many batteries are fire hazards!!!
Best Buy (Zambia, Tanzania) has a recycle program.
Please return to share results.
Thanks!
Jimm
Nov 20, 2012 | Computers & Internet
Hi. Have problem with my Amilo notebook Pa 3553. The problem: if i turn off my laptop and try to turn on again, it starts but won't turn on the screen. I have to swich off and on multible times to get...
Could it be a loose connection to the monitor itself, check your hardware's integrity. If everything boots, try re-installing your graphics driver again.
Nov 03, 2012 | Computers & Internet
( Dell xps m1530 laptop ) Monitor blank, powers up but screen won't come on.
It ISN'T the LCD screen. Since you diagnosed with an external VGA monitor, you now know the problem is the laptop.
(When you connect an external VGA monitor to a laptop, you are bypassing the Video Cable, and LCD screen. You are connected directly to the laptop )
The basic Windows files aren't being found. The boot files. This may mean a bad Harddrive.
Do you have the Restoration CD Disk? Laptop on insert it into the optical drive tray, close the tray.
When asked choose - Repair. (Non-Destructive Installation)
If a checkdisk is done, you have bad sectors on the harddrive.
There IS a special procedure in replacing a harddrive.
[ More information on Harddrives,
http://computer.howstuffworks.com/hard-disk.htm ]
Regards,
joecoolvette
Feb 26, 2012 | Dell XPS M1530 Laptop
Amilo notebook pa 3553 xwindows vista drivers
on this page
http://ts.fujitsu.com/support/downloads.html
select your operating system and go.
If this helps orsolves the issue, please rate it and give a testimonial for myresponse.
Feb 27, 2011 | Computers & Internet
I don't know how to turn on wireless on my laptop model fujitsu siemens amilo pa 3553 thanks and please help.
Hi
please try FN bottom right blue key plus F2 just about the no 2 key
FN+F2 or it could be one of 3 different launch keys on the right just above keyboard
Feb 03, 2011 | Computers & Internet
I need to replace the power push button, but do not know what part number it is. Trying to get it ordered through Mouser, but there are too many listed. All I know is that it's an Alps switch, and it reads...
HI,
I've just had a Roland Micro Cube amplifier in for repair and it uses the same type of Alps switch you mention. ( It's also broken )
This is a simple single-pole latching push-button switch, so electrically, almost anything rated for an amp will be good enough.
Alps no longer make the same part, so you'll need to find something which looks the same and fits the original hole.
My repair is easier, because the replacement part doesn't have to match anything.
Graham.
Jan 27, 2011 | Roland CM30 CUBE Monitor Speaker PA...
HP zv5430us laptop has no video. Blank
The laptop has a built-in video card and the video RAM uses part of the main RAM.
First, re-seat the RAM modules and if the laptop still does not boot up normally then remove the RAM and get it tested at your friendly computer repair shop.
If the RAM is OK then connect an external monitor to the laptop, power up the monitor first and then the laptop. The video data should divert to the external monitor automatically, if you do not get any video image on the monitor then the video card in the laptop is faulty and a motherboard replacement is required.
A replacement motherboard may not be a cost effective solution and If it was me, I would put my money on a new laptop. I would then remove the hard disk and insert it into an USB adapter case and use it as an external USB hard drive.
Mar 22, 2010 | HP Pavilion zv5430us (PR466UAA) PC...
Computers & Internet Logo
89 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Ekse
Erni Mallari
Erni Mallari
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
