The error you are receiving is a bad water valve inlet problem. It's typically the cold inlet, but it's better to replace both.
Depending on the type of water you have, the valves could have lots of sentiment blocking the filter screens inside the valve, which can be cleaned, you'll just need to remove the water hose attached, and check.
If your valves look clear, then they have just possibly failed, and need to be replaced.
