The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
Same thing happened to me with an IPOD. When I plugged it in to one of my USB ports, it ******** up all the USB ports. I suggest reinstalling the drivers for your USB Ports. Then install the software that came with your MP3 Player before replugging it in. Good luck :)
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. If your printer is connected via the USB cable, disconnect your printer from your computer. Reboot your computer. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Try to scan again.
If that doesn't help, try to reinstall the printer software on your computer. This will help repair any corrupted files necessary for scanning or printing.
A quick to fix to most communication problem is to reboot your system. Disconnect the printer from your computer. Reboot your computer. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Try to scan again. When scanning using the scanner glass, the scanner light will move across the glass to scan your original document. The printer will then process the image and sends it to your preferred application on your computer.
Is it a new harddrive in a external case..if so i have the same prblems and i have to remove the harddrive and insert it into my computer and format it 1st...then place it back into my external case...
If you have used it before,then the best thing to do is try it on an other computer,if that doesn,t recognize then try a different usb cable,if still no go...then the harddrive might be either virused up...then you will have to put it in your computer to virus scan.or your harddrive may be faulty...
Or the last thing...if it is a new external google your motherboard because if it is a old computer your trying to use it on..it may not regonize the harddrive if the capacity is to large..
Hope this helps..if so please take the time to rate it,and if i can be anymore help.
is the issue a power 1 or does it power up but your computer doesn,t regonized the harddrive within the external...have you tried a separate power supply/usb cable....or try a different usb port in another computer
I can help you with this. Follow these instructions-->
Start-->Control Panel-->Administrative Tools-->Computer Management, under the Storage section select "Disk management". Locate the external harddrive, and then change the drive letter. Select the external drive. Right click, and select "Change drive letters and paths"-->Highlight the driveletter to change-->Click the "Change" button-->From the drop-down list choose an unused drive letter, and hit Ok. The external drive should be recognized and accessible at this point.Let me know if you have any other questions. Thank You,Raph30
I have one in the uk, some blue ray discs are region encoded (some work some don't). Uk DVD's don't work and neither do old uk playstation 1 or 2 games. However all PS3 games are region free and work fine.
