Hi.
The board you are talking about is called Z-sus. Its role is to sustain power to the plasma panel. If the Z-sus board fuses keep blowing, then the board is usually shorted, and the repair is done replacing the board.
In some case a defective PSU can cause the Z-Sus fuses blowing.
When the Z board is failing, the Y board must also be tested.
The Z board should be the same as this one. Check model and test the part before purchasing.
Regards.
Ginko.
Hi:
This is the X-systain board replace this board and your problem will be solved. The part number can be found on a white sticker some where on the board. Get the number and google it or enter it on E-Bay because alot of shops sell these boards when the get units with bad screens. Or try www.shopjimmy.com for a new board.
