Question about Samsung Galaxy S GTI9000 Smartphone
Sim network unlock code for samsung galaxy s,what to do
Posted by jli524 on
adeel malik
  • 258 Answers
possible ways to get an unlock code:
-ask ur current operator to give u an unlock code
-go to any mobile repair shop and get ur mobile unlocked via box device
-follow the links below:
http://www.mrunlock.com/
or
http://www.moneysavingexpert.com/phones/unlock-mobile-phone
or http://unlock-zone.com
Posted on Mar 10, 2011
Locked out of my galaxy s7 phone cannot remember my pin
I guess Samsung galaxy mobile is locked due to you have entered unlock key more then 5 to 10 times. And now your samsung galaxy mobile is freezed and hard locked.
Now to Unlock samsung galaxy mobile you need unfreeze code and then sim unlock code or sim network unlock pin. You can generate unlock code from imei number of your mobile. it generate 4 codes. First is your sim unlock pin and last is defreeze code.
You can also try this alternate method for unlocking your galaxy mobile.
If you have rooted your mobile and want to unlock it without code then You need custom rom , bootloader unlock file and also flashing tool. And also download samsung driver from samsung site.
Now once mobile is rooted flash rom on it and unlock bootloader for samsung unlocking.
Instead of this you can also try this method to unlock your samsung mobile.
Enter into service mode of samsung mobile by following command *#27663368378# or *#0011#.
then choose debug screen then network lock then select parso sha256 off option. now once your mobile is rebooted it wan't ask unlock code. Howto network unlock samsung galaxy s7 edge
Oct 01, 2017 | Galaxy Cell Phones
Need a free unlock code for a galaxy s5 t mobile
Get the unlock code for Samsung galaxy s5
https://www.unlockninja.com/unlock-samsung+galaxy-s5
Here is the steps to follow
-Select Purchase country
-Select Locked Network
2nd step-0bcom1mm0st3g0cuhhyck11m-1-0.jpg Apply to get the unlock code by update the IMEI
Type *#06# to know IMEI NO
) to unlockninja porta
The code will be delivered to your mail ID.
Here is the process to use the code
Just follow these simple steps to
  1. Switch ON your Samsung Phone with a not Accepted SIM Card.
  2. Samsung will ask for "Password".
  3. You can now enter the Unlock Code we send to you.
  4. The phone is now unlocked to use any network SIM
https://www.unlockninja.com/unlock-samsung+phone phone unlocking service-unlockninja-0bcom1mm0st3g0cuhhyck11m-1-2_0.jpg
Nov 22, 2016 | Samsung Galaxy S5
Unlock my phone it is a samsung galaxy j2
Effective Way to Recover Lost Files on Samsung Galaxy
I think many users are highly proud about owning a Samsung Galaxy. But, the problem arises when they lose some crucial data from SAMSUNG Galaxy regardless of whether it happens due to accidental deletion, unintentional formatting, factory resetting without backup, Android OS update or any other reason for that matter. When files get deleted from Samsung Galaxy S9, a powerful data recovery on your Samsung Android phone is your ideal tool.
Android data recovery software is actually an amazing application for getting back and retrieve lost files from Samsung Galaxy.
Directly recover deleted or lost data from mobile phone.
Retrieve deleted files from internal memory and external SD card.
Get back photos, call logs, contacts, video files, text messages, whatsapp, etc.
Restore lost data from broken or locked Samsung device.
One-click backup and restore Samsung phone or tablet.
Support Galaxy S9/S8/S7 Edge/S7/S6 Edge/S6/S5/S4/, Galaxy Note 8/5/4/3, Galaxy J7/J5/J3/J2, Galaxy A9/A8/A7/A5/A3/ and more.
LEARN MORE
Apr 29, 2016 | Samsung Cell Phones
Can u find me a code to unlock Samsung galaxy exhibit IMEI 359874041306247. THANKS
Hello. You can definitely unlock your T-mobile network locked Samsung Galaxy Exhibit using unique unlock code. You can get the unique unlock code for your Samsung Galaxy Exhibit from Mobile-Unlocker.com at affordable cost with an easy unlocking guide. But you can unlock a GSM network locked phone to use any other GSM network SIM card only. Verizon is CDMA network provider. You cannot use it with the unlocked phone.
Feb 11, 2015 | Samsung Cell Phones
Unlock new Samsung note 4 from etisalat network
Hello. You can unlock your Etisalat network locked Samsung Galaxy Note 4 safer and easier using unique unlock code. You can get the unique unlock code either from the respective network provider or from any trusted vendor online. Good luck.
.................UNLOCKING INSTRUCTIONS.................
Method 1:
1 - Switch ON your Samsung Galaxy Note 4G with a NOT ACCEPTED SIM Card.
2 - Samsung Galaxy Note 4G will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung Galaxy Note 4G shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung Galaxy Note 4G.
3 - Compose : #0111*CODE#.
SOURCE: MobileUnlockGuide.com
Jan 07, 2015 | Samsung Cell Phones
Unlock imei on tmobile samsung galaxy s4
You mean you want to IMEI unlock the locked network on your Samsung Galaxy S4?I suggest you can approach Theunlockarena.com and specify the country,locked network of the phone.Based on the availability you can get the unlock code along with free instructions.
Oct 09, 2014 | Cell Phones
How to unlock
If you are asking for a network unlock, The best way to unlock a Samsung i5510 Galaxy 551 mobile phone is using unlock code. You can get the unlock code for a Samsung i5510 Galaxy 551 mobile phone from
ClassicUnlocking.Com at affordable cost.
UNLOCKING PROCEDURE FOR SAMSUNG i5510 GALAXY 551
1 - Switch ON your Samsung i5510 Galaxy 551 with a NOT ACCEPTED SIM Card.
2 - Compose : #7465625*638*CODE# (or *#7465625*638*CODE#).
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung i5510 Galaxy 551 is locked to.
CODE: Its the unique Unlock Code for your Samsung i5510 Galaxy 551.
Apr 12, 2014 | Samsung Cell Phones
How do I unlock a samsung galaxy s.
Try code from Online site and UNLOCK IT......
Sep 19, 2011 | Samsung Cell Phones
Samsung Galaxy S GTI9000 Smartphone Logo
595 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
John Tripp
John Tripp
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
