Question about Maytag M3X05F2D Air Conditioner
No problem with unit. Is this air conditioner CSA or OSHA approved ?
Posted by junethurston on
lyndseymama
    Scholar:
  • 42 Answers
It's not the unit that you have to worry about for CSA or OSHA. It's how you intend to install it. You have to use the proper installation guidelines as approved by OSHA. I do know that going outside a wall or window you must have the proper bracket/frame installed outside the exterior wall to prevent it from falling on someone's head if high enough. If down low, they still have to be braced/bracketed properly to avoid injury. That's standard procedure.
http://www.osha.gov/SLTC/indoorairquality/
You need to find out what OSHA has for safety guidelines and restrictions. Also check with your local building code office to check with their pre-set guidelines. They have to be automatically in compliance with OSHA if they intend to operate guidelines for business purposes. So Call either- or both. It's not the unit you need to worry about unless it's very old. Good Luck.
Posted on Mar 10, 2011
I want to hook up a permanent drain system. Where can I find a hose which will fit onto the drain plug of my PMMB14000E?
Your unit is not intended or approved to have a continual draining function. Some water must remain in the unit, to cool the coils during the cooling operation.
Hope this helped you and thanks for choosing FixYa.
Aug 09, 2011 | Amcor 14000 Portable Air Conditioner
MODEL # FAH124N2T BLOWS WARM AIR. SOMEONE TOLD ME THIS TYPE OF THUR THE WALL UNIT CANNOT BE REFILLED WITH FREON. TRUE?
Part of it's true. Freon is no longer approved by the EPA. R134a is the only refrigerant gas that is now approved in place of Freon. It will also require removing the chassis from the outer housing to capture any freon that's left in the system, as well as recharging the high and low sides of the compressor. It does require specialized equipment to do it properly. It's best left to the professionals.
Hope this helped answer your question, satisfactorily.
Jul 13, 2011 | Frigidaire FAH124N2T Air Conditioner
How can I put antifreeze in a Samsung air condition?
I don't believe you should put any antifeeze in a a/c unit.
Jul 08, 2011 | Samsung AW1093L Air Conditioner
The heating and cooloing system is not working. There is no heat or air conditioning coming through the vents.
  1. Check the air conditioner fuse and replace as necessary.
  2. Air conditioner system discharged. Have the system evacuated, charged and leak tested by an MVAC certified technician, utilizing approved recovery/recycling equipment. Repair as necessary.
  3. Air conditioner low pressure switch defective. Replace switch.
  4. Air conditioner fan resistor pack defective. Replace resistor pack.
  5. Loose connection, broken wiring or defective air conditioner relay in air conditioning electrical circuit. Repair wiring or replace relay as necessary.
Dec 16, 2010 | 2005 Cadillac Deville
I would like to know the correct way to take freon r22 out of an unit..
You must have a reclaim machine and a reclaim tank and the old refrigerant must be taken to an approved EPA site for recycling.
Jun 19, 2010 | Whirlwind FH-778 Air Conditioner
All air stopped blowing in through the vents.
o air coming from air conditioning vents
Apr 27, 2010 | 1986 Toyota Camry
About 4 years ago I had a LAARS MAX boiler installed with a Beckett burner and a Superstor water heater. All works well - except minor problem with burner needing to be reset occasionally. BUT when I...
First off they are not suppose to be installing a boiler that is not CSA approved. Your best bet is to contact Laars find out the real truth. I do know Laars was bought out by another company a few years ago, but the Installation company needs to stand by their product and be held accountable.
If unit is not request a new boiler or threaten talking to better business bureau Customers have rights. It also can be a liability to them.
Good luck let me know how it turns out
Jan 04, 2010 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Have lost charger or the 2 prong adapter. Not sure as we have a 16 volt charger with single prong that may be for our light. Need to know what voltage required for the light to be sure.
According to the instruction manual for these swimming pool lights, the charger specifications are the following:
USA and CANADA: 14 VAC,1.5A UL/CSA-approved wall plug
adapter and charger
AUSTRALIA and NEW ZEALAND: 240VAC 50Hz/14VAC 1.5A wall
plug adapter and charger
EU: 220-240VAC 50Hz/14VAC 1.5A CE-approved wall plug
adapter and charger
SOUTH AFRICA: 220-240VAC 50Hz/14VAC 1.5A wall plug
adapter and charger
UK: 240VAC 50Hz/14VAC 1.5A CE-approved wall plug adapter
and charger
Aug 13, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
Bad Odor
You need to clean the indoor coils with a coil cleaner. Its probably mold that has been dormant until you turned the unit on and it became wet. Clean the indoor coil real well with an approved cleaner. Some Home Depot's carry a coil cleaner that is in a spray bottle.
Apr 11, 2009 | Frigidaire FAC107P1A Wall/Window Air...
Maytag M3X05F2D Air Conditioner Logo
170 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Marvin
Marvin
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
