I have a Brinks Fire Resistant safe Model number 5054 ser. number 185268 I have the key and the safe will open but I lost the combination. If the dial is moved I will not be able to open the safe. Can you give me the combination.
You do not need to go to a locksmith - you can get a new key much more inexpensively by contacting Honeywell (the parent company for Brinks safes) at 1-800-223-8566
When you call Honeywell, you will need to provide your safe's model number (5059) and the serial number (usually found on the right of the safe, near the model number).
At the company's discretion, sometimes they require a notarized affidavit confirming ownership. There is a fee for a replacement key (it was $15 last time I checked, but may be higher now), but it is much less expensive than going through a locksmith (who will generally just do the same thing as described above!)
This lock is a pin tumbler lock and can be impressioned by a locksmith. If you can't find anyone in your area that has the blanks you can send the lock to A1-Locksmith and we will make you Brinks key's
Here is the turning sequence: General Turning Sequence Instruction NOTE SAFE MODEL 5054/5055/5059/5080/5081/5084/5111/5190/5195/5575/5700/5702.
Combinations consist of FOUR (4) positions (numbers). BEFORE YOU START Before you begin, please clear all settings by turning the dial CLOCKWISE (to the right) three times. We also recommend to try the procedure with your safe door open first. Then follow these steps: TURNING SEQUENCE 1. Start the dial on 0 (zero). 2. Turn the dial to the RIGHT, passing your first combination number FOUR (4) times and stopping at that number on the fifth time around. 3. Turn the dial to the LEFT, passing your second combination number TWO (2) times and stopping at that number the third time around. 4. Turn the dial to the RIGHT, passing your third combination number ONE (1) time and stopping at that number the second time around. 5. Turn the dial to the LEFT, to the last combination number and STOP. 6. Insert the key in the cylinder lock and turn RIGHT to open. Your safe should now be opened.
You can mail a notorized letter, requesting a combination...include model and serial number...mail to Sisco, 2835 E, Ana Street, Compton, CA 90221.....or fax it to 310-638-3489. I had the same problem and found out thru a Brinks website.
To bad you dismantled. Here is the turning sequence: General Turning Sequence Instruction NOTE SAFE MODEL 5054/5055/5059/5080/5081/5084/5111/5190/5195/5575/5700/5702.
BEFORE YOU START
follow these steps:
TURNING SEQUENCE
