The PC video resolution is too high, native resolution for this monitor is 1280x1,024 @60Hz. Basic LCD monitor and TV troubleshooting guide: Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
It does not make sense thogh thst you get blank sceen on safe mode, you may have video card set up problem. Does it work with another PC? Cna you try another monitor with thsi PC?
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Thank's for the reply,
There's the rub cant't access screen properties to adjust settings, so don't even know what resolution or refresh rate is set to at present.
Yes the card does work in another PC, will see if I can get it on another monitor as you suggest.
Weird thing is when unplugged from the graphic card and plugged into the VGA motherboard socket everything that has been tried while on the graphic card shows on the desktop, even though the on board graphics are disabled.
Cheers smee.
