SOURCE: Registration of Calls
My phone had the same problem on the same day... weird!! done a little investigating and it seems that if you go on the main menu then select calls, then on that screen press the "more" button then select "delete all" - then Jobs a good'un - phone should be working again!!
SOURCE: cant copy the numbers from my phone to my new sim card
this problem is due the sim space may be u have 32k or16 k sim . so memory is nt enough to save all the contacts - so do these things to solve ur problem .. 1) if u have an alternative sim which is 64 k sim then copy all the contacts in that sim then transfer them to ur required phone afterwards ... 2) if u any other alternate phone than transfer half the contacts in first atempt than transfer rest the contacts in other atempt...
SOURCE: Application Watcher Main Thread?
Friends, this I got from allaboutsymbian website. And I already try the Test1 and it works!!!
Hope this could be much of help......
~~o000000o~~
I had the exact same problem and have solved it by updating the
firmware and reloading my settings from at saved bile, but it is rather
time consuming.
The solution by deleting all the messages in the inbox worked perfectly fine
Though nothing haapend when i only deleted the outbox and sent.
I assume that the problem is caused by the message server (the small program handleing you enter to send and read messages)
I descuvered that when my phone was put into offline mode, and
re-entering to normal mode , I could not open the message server.
After deleting all messages this problem has been resolved aswell.
Maybe the message server is having problem handleing to many messages.
The amount of space left on my phone was not a problem eather, arround 30 M and the insert card was empty.
but i had over 1300 messages in my inb ox when the problem started occuring.
If any ojne else is experiencing this problem, pleace keep on debugging and tributed with more result.
This will make it easyer to conclude on the results and finally determine why it is happening, based on when.
Test1 : (Is the issue resolved only when inbox being emptyed)
Here is what you do :
1. Delete all you messages - 1 in your inbox,
2. Restart the phone,
3. Send an sms to yourself.
4. Write a reply on this threat weather youi got the message or not.
if it is not resolved. please continue with 2. test
Test2 : (Is this allways resolved by emptying the indbox)
1. Delete ALL you messages in the inbox
If the problem is stille not resolved then you have to reset the phone.
Test 3.
First of all, you must save all you phone settings, phonebook
sms(despite you just deleted them all, save it anyways!) phone
settings. etc.
and then reset it.
1. Save all files
2 Reset you phone by typing in *#7370#.
3. Restart the phone,
4. Send an sms to yourself.
5. Write a reply on this threat weather youi got the message or not.
If this works, then restore one of the save configurations at a time and test weather it still works.
SOURCE: got the w880i and they ask to format anyway. so then i click yes
Connect your phone to XS++, go to the GDFS tab, and select the "read
phone lock code" option. Then as your phone is sony, your phone lock
code will be set to 0000 again.
download XS++ from here:
http://forums.se-nse.net/index.php?showtopic=16338
SOURCE: Sony Ericsson K800i cant make of recieve calls, and inactive sim!
mikey....not to worry after reading your problem i found it a software problem ......give that phone to your retailer for software formatting and every thing will be ok.
