To load more lead into the Zebra Z Grip mechanical pencil you must follow these steps:
1. Use the extra provided lead or purchase a refill package in 0.7mm size.
2. Remove the plastic cap that covers the eraser on the end of the pencil.
3. With the cap removed, gently tug the eraser out of the end.
4. When the eraser is removed, place a few pieces of lead into the open tube.
5. Insert the eraser.
6. Replace the cap on the end of the pencil.
7. Depress the end of the pencil a few times to feed the lead through the tip.
8. Write!
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
