Question about Archos 2 Vision MP3 Player
Archos 18 vision 8gb. Battery will not charge. Conects ok with usb cable. Battery shows up initially and charges but stops ater one seconond leaving battery icon swowing. Assumed this was correct but battery still not charging. New unit.
Posted by rw010a0206 on
  • rw010a0206 Mar 14, 2011
    Item returned to seller. Thanks
Aloke Das
  • 1,833 Answers
According to you your MP3 player is not working for battery. Make sure the charger is OK and working fine. You can change or replace the battery. Your battery circuit unit may be faulty. You can try to charge it in turn off mode of the player. If it is new unit then the player is in warranty. Then you can go to the nearest service center or your retailer for repairing or replace.
Posted on Mar 10, 2011
Archos 18c vision mp3 will not charge
I think the USB cable is defect, or one of the connectors, on the tablet, computer or even on the cable. First try a new cable and check if nothing is in any of the connectors, like dust or other debris.
Jan 18, 2015 | Archos Audio Players & Recorders
Hi i have a archos 18 vision and i can not get my ps3 to conect with it so i can down load music
Does the MP3 player charge when it is plugged into the system?
if not then you may need a different USB lead, if it DOES charge, it may be the case that the device is formatted in a way that prevents computers (or playstations etc.) accessing music without certain software. my personal solution for this was to put all of your music from your computer onto a USB stick and copy it over to the PS3. You can copy music from iTunes by selecting tracks and pressing CTRL+C, I believe the same applies in windows media player
May 04, 2011 | Archos Audio Players & Recorders
My archos vision 1 is not recognised by computer
Hi, archos vision 1 player not recognized by the computer
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see archos vision 1 player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the archos vision 1 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: archos vision 1 Players can connect to your computer in MSC or MTP mode. Exceptions are archos vision 1 Connect and archos vision 1 Express which only use MTP mode. MTP mode is the recommended and default method for archos vision 1 Players when used with Windows OS.
The archos vision 1 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Have a nice day....
Feb 19, 2011 | Audio Players & Recorders
Hi I have just receieved my Archos Clipper 2GB, could you please tell me the best way to charge the battery?
You have to plug it into the computer with the usb cable that came with it. Watch for the red led light to stop blinking. Computer must be turned on to charge.
Aug 09, 2010 | Archos 404 Digital Media Player
I am not able to connect my achos to my pc or laptop. When I attached the cable from my achos to my system; it charges the battery but I cant access the hard drive and other files
If you plug the Archos when it is off, wait until main screen appears, press OK button when the message about charging pops up, then press MENu and scroll down to the USB options, select hard drive mode. Please read the manual you can download at Archos official site/support/downloads
Apr 05, 2010 | Archos 504 500870 Digital Media Player
Strange ARCHOS 5 power adapter
The AC adapter did not work - it never charged the battery so I discarded it but never found any reference to it on the Archos web site.
Jan 27, 2010 | Archos 5 Internet Media Tablet
Archos won't connect by USB to computers
You should keep your eye on the device after its been plugged to the PC it will give you 2 options "charge" or "usb" you ca not establish a connection without picking usb connection option on the Archos screen when it pops up. If you are doing so and problem still existed then i would recommend you to download the latest windows media player. Because it comes with new devices sync driver update.
Aug 10, 2009 | Archos 605 Wifi Portable Multimedia Player
Archos 404 does not work at all since using Archos Docking Adaptor
You should try to only chare your Archos only when it is completely dead and charge it fully then the battery will be regular
May 02, 2008 | Archos 404 Digital Media Player
How long can it possibly charge for the first time?
With USB mains charger it takes approx 18 hours for the first ever charge so I would hate to be using the usb to pc to do the same.
Once this initial charge is achieved though it will charge by usb to pc as you work even though it does ask "usb connection or Charge"
Feb 03, 2008 | Archos 605 WiFi Digital Media Player
Archos 504 Powers Up and Immediately Shuts Down!
bad battery bad ones will show charged but cant push out full violts pc needs ok buy new one 1st
Jan 28, 2008 | Archos 504 500870 Digital Media Player
Archos 2 Vision MP3 Player Logo
1,359 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
Harrie
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
