Question about Philips Car Audio & Video
Audio systems code - Philips Car Audio & Video
Posted by gz68 on
adeel malik
  • 258 Answers
The new stereos are unlocked by an unlock cd.following are the options to obtain an unlock code for the stereo:
1-contact ur car dealer and ask him for the unlock cd.
2-go to some good car stereo shop and ask them to unlock the stereo 3-if u r a wiz kid, wrie the model of ur stereo in google and search it for an unlock cd and burn it and insert it in the stereo.
Posted on Mar 10, 2011
Need radio code for 2006 suzuki FORENZA
A local dealer can help. They will have a code based on your VIN. Also, you can try this: The audio security system is activated whenever the audio system circuit is disconnected from the battery. A four-digit security code must be entered in order for the audio system to resume functioning. The security code is stamped on a card located in the vehicle (usually in the glove box). The following security code entering procedure must be used to deactivate the audio security system:
After connecting the audio security system to the battery, "CODE" will flash on the display.
Enter the proper security number into the unit, using the preset buttons No. 1 through 8.
For example, if the security number is "1234":
Press the preset button No. 1. "CODE" will disappear and "1 --- " will appear on the display.
Press the preset button No. 2, and "12 -- " will appear.
Press the preset button No. 3, and "123- " will appear.
Press the preset button No. 4, and "1234" will appear and flash three times.
The audio system will function and will transfer to the radio. If the incorrect security number is XXXXX into the unit, "Err" will appear followed by "CODE" and there will be several audible beeps. If this happens, repeat the security entering procedure beginning with Step 2.
If, after repeated entry of the wrong code, unit will enter "lockup" & will need to be repaired
Oct 07, 2015 | Suzuki Cars & Trucks
I removed and the radio stopped.pls help me with the code.serial# U2200L3802
posted 6 times. RTM , its all there, read it.!!
2008 opr.guide.(lost it, huh?) Accord. non satellite
Quotes:
Your vehicle's audio system may disable itself if it is disconnected from electrical power for any reason.
To make it work again, you must enter a specific five-digit code with the preset buttons.
Because thereare hundreds of number combinations possible from the five
digits, making the system work without knowing the exact code is nearly impossible.
You should have received a radio code card that lists your audio system's code and serial numbers. {glove box find}
It is best to store this card in a safe place at home. In addition, youshould write the audio system's serial number in this owner's manual.
If you lose the card, you must obtain the code number from your dealer.
To do this, you will need the audio system's serial number.
If your vehicle's battery is disconnected or goes dead, or the radio
fuse is removed, the audio system will disable itself. If this happens,
you will see ''ENTER CODE'' in the frequency display (on the screen on models with navigation system) the next time you turn on the system.
Use the preset buttons to enter the five-digit code. The code is on the radio code card included in your owner's manual kit.
When it is entered correctly, the radio will start playing.
If you make a mistake entering the code, do not start over; complete the
five-digit sequence, then enter the correct code. You have 10 tries toenter the correct code.
If you are unsuccessful in 10 attempts, you
must then leave the system on for 1 hour before trying again.
The system will retain your AM and FM presets even if power is disconnected. {only on newer cars'
General information on Honda and DIY:
{the code can be obtained from any Honda dealership (you must give him/her your radio serial number (sticker off radio)"}
or any locksmith with a license from..NASTIF
Honda1 ServiceExpress (Same info as ISIS)
Acura ISIS (Dealer version w/ advanced search)
http://nastf.org/i4a/pages/index.cfm?pageid=3462
Nov 26, 2013 | 2002 Acura MDX
Radio code
here is what you lost: Typical of all newer cars...
All 3 ways: DIY,dealer or locksmith.
Quotes:
Because there are hundreds of number combinations possible from the five
It is best to store this card in a safe place at home. In addition, you should write the audio system's serial number in this owner's manual.
If you make a mistake entering the code, do not start over; complete the five-digit sequence, then enter the correct code.
You have 10 tries to enter the correct code.
Aug 22, 2013 | 2001 Honda Accord
Code to nulock the audio system purchased from a wreckage shop(1996 audio system).
this needs to be obtained from the dealership. You can call them and get it from the parts department. It is the only way to get this information other then to check the back of your owners manual it my have been written down there when it was first purchased.
Jun 05, 2011 | 1997 Acura TL Series
Code for radio/cd honda civic 2003
Try to locate the unique code number that will unlock the theft-protected audio system on your 2003 Honda Civic. It probably was imprinted on an anti-theft identification card that you should have received when you acquired the car. The code was printed on a document that came with your owner's manual packet
If you do not have the code, you will need to track down the audio system's serial number. In the case of the 2003 Honda Civic, finding the serial number may require seeking assistance from a Honda dealer. The dealer should be able to determine the audio system's special code number so you can reset the radio. With some newer Honda Civic models, the serial number can be retrieved electronically from the radio.
If you are able to locate the serial number of your 2003 Honda Civic's audio system without a dealer's assistance, you can obtain the special code by going online to the Honda Web site. You must first provide specific information to prove you own the car. For instance, you will need the Civic's vehicle identification number, or VIN, and the audio system's serial number.
When you know what the audio system's special code number is, use the preset buttons on the car radio to punch in the digits. This should reset the audio system, enabling you to resume using the radio and the CD player.
Read more: How to Reset Radio Information on a 2003 Honda Civic ' eHow.com http://www.ehow.com/how_6056947_reset-information-2003-honda-civic.html#ixzz1FGPZq81d
Feb 28, 2011 | 2003 Honda Civic
My Blue-Ray Home Theatre System Model SA-BT207 unable to read blue-ray disc for Region Code A and C. How to solve it?
Please follow the steps : To change the player region code
1. Be sure players drive is empty (nodISC)
2. Enter following key sequence using remote control:
Enter, 6, >=10, <<, 00F2, Audio, 8, * requested region code here (1-8) *, Subtitle, 1
3. Player will reset and requested region code will be set.
- For example to set region code to 3 press: "Enter, 6, >=10, <<, 00F2, Audio, 8, 3, Subtitle, 1"
To set the player to RCE proof region free
Enter, 6, >=10, <<, 00F2, Audio, 8, 1, Subtitle, 4
3. Player will reset and set to "region-free" and "RCE-free" mode
To restore players factory region code
Enter, 6, >=10, <<, 00F2, Audio, 8, 9, Subtitle, 1
3. Player will reset and set to factory region code
Regards, Jay
Oct 30, 2010 | Panasonic Home Theater System System
Replaced battery and navigationn propt me to put a code. inputed the code and it shut off.
If you replaced your battery, you probably lost your audio system code as well. You should put that in first or your navigation system voice will not work. I assume you have the code for your audio system.
After you get your audio system working then you should be able to put the code in for you navigation system as follows:
Enter the four-digit navigation system security code, then select Done. If you have entered it correctly, the display changes to the Disclaimer screen. You have ten chances to enter the correct code. If all ten are incorrect, turn the ignition to OFF, then back to ON (II) to have ten more chances to enter the correct code (I would try this is your unit has turned off and doesn't come back on).
If you have other questions on this, leave a comment and I will investigate further.
Hope this helps you.
Nov 18, 2009 | 2006 Honda Accord
2007 Honda Civic Navigation Screen went black
Had same problem with 2008 Honda Civic.
Note: you will need anti-theft code so get it first!
Solution:
1. Turn ignition off.
2. Look for fuse box under steering wheel.
3. Remove fuse #35 which is for the Navi-audio unit.
4. Then re-insert the fuse. This will reset the system.
5. Turn ignition on and the Navi-audio on. Buttons WILL be working now.
6. The unit will request for the anti-theft code for Navi-audio system. Enter the 4 digit code....Yippee!
However, I lost all my radio preset stations. Thankfully my saved destinations in navigation system were intact.
Apr 02, 2009 | BoxWave Corporation 2007 Honda Civic...
Car audio code
my car audio system becker
modek no; BE 3101
serial no;Y 10 20 947
its want the code
Mar 17, 2008 | Audiovox MMDV2
Car Audio & Video Logo
158 people viewed this question
Top Philips Car Audio & Video Experts
Colin Stickland
Colin Stickland
Marvin
Marvin
john h
Are you a Philips Car Audio and Video Expert? Answer questions, earn points and help others
