First before you do an overhaul try Seafoam
You can google it. Do a few oil changes with it and it should clear. Your problems comes from oil sludge and carbon deposits
Seafoam is designed for that purpose
Once you can clear the clog you oil pressure will rise back to normal
? 3:22
https://www.youtube.com/watch?v=DPcoLEHEt1I
Nov 30, 2010 - Uploaded by JT
me trying to figure out how to realign the dual-cam pulleys that shifted when I removed the timing belt, shifted ...
? 14:47
https://www.youtube.com/watch?v=jLkdnkFW9c0
Aug 10, 2012 - Uploaded by TheBGravit
Replacing the timing belt on my 2002 KIA Rio. ... Hubitools Universal Timing Gear Clamp - Duration: 1:26. Hubi Tools 618,464 views. 1:26. How to Align the Camshaft if My Timing Belt Broke : Timing Belts & Other Auto ... Kia Spectra Timing Belt Replacement - 1.8L DOHC Engine Part 1 - Duration: 11:36.
Hi Christo. If you hear a tappet noise when the engine is started, and it goes away after a few seconds, if is not a very serious problem. What is happening is that you have Hydraulic lifters that maintain they're adjustment when the motor is not running. One of the lifters is collapsing. When you start the engine it pumps back up and works. Since lifters are at the top of the engine, you should that you use. It is called "Sea Foam". It is an excellent product to ad to the oil. It helps keep the engine cleaner and removes any moisture from the oil. It is great with hydraulic lifters. Just so you know the difference. If you have a sticking lifter, you will have a constant tapping sound. I have used Sea Foam to un-stick lifters successfully. IMPORTANT NOTE: A WORD ABOUT THE REPLACMENT OF THE KIA RIO TIMING BELT.
It is recommend that the belt be changed at 60,000 miles. I also recommend that the dealer do it. If the car is under warranty you must tell the dealer to replace it. If you do not tell them to replace it, THEY WILL NOT. If the belt breaks, it will DESTROY the engine. Hope this is helpful to you. Happy New Year Greetings, Mark
Hello mfriesner71; my name is Roger and I will answer for you. The correct plug gap is 0.027 to 0.031.in. Any gap between these will work fine. Just make sure they all gap the same. Should you need further help please just ask. Please rate the answer. This way I know it was helpful. Thank You for using Fix Ya. Roger
