Question about Sylvania 6432TE 32" TV
Im want to use my sleep timer on my sylvania 6432td and i just switched to direct tv and dont have the original tv remote any way i can use this feature
Posted by matt2010boog on
John Snow
    President:
  • 788 Answers
I am sorry, you will need the original remote or a remote that is similar.
You can check out 1800remotes.com and see if they chan help.
Thanks
asnowman
Posted on Mar 10, 2011
Can't set sleep timer on my mitsubishi cs-40505 tv. I do not have the original remote. How can I set the sleep timer?
U can't do it without the original remote.Go in the tv menu by the manual button control might could set the sleep timer.This is a extra option on most tvs.
Jun 07, 2010 | Mitsubishi CS-40505 TV
Sylvania 6432TD turns off within a second of turning it on
Had same problem Sylvania SRT2232s 32"had to keep powering on and off until it warmed up enough to finally stay on. Problem was the 100/50 & 1/50 filter cap took it to local repair total cost to fix was 74.52 works better than ever
Mar 06, 2010 | Sylvania SRT2232S 32" TV
How to turn the sleep timer off
You obviously don't have a menu button on the set itself. Unplug the unit and remove the back cover, this should expose the info you need unless it was placed on the outside and is now lost. Without TV model it will be difficult to get any helpful assistance. Good luck.
Jul 05, 2009 | Televison & Video
REMOTE DOES NOT WORK ON SYLVANIA TV
well, i got a one for all remote from a wal mart or some where else, and i have a sylvania tv. it works for my tv. might want to look into that. www.oneforall.com
May 27, 2009 | Sylvania Televison & Video
This TV has a sleep mode
There are two ways to solve this, but both will require using the original remote for the Magnavox. The original remote has a SLEEP button - press it until the screen says Sleep DISABLED or Sleep OFF.
Or make sure the TV is in TV mode, and Press Menu --> TV Steup --> Sleep Timer --> change to DISABLED
-Tha Mp3 Doctor
Feb 20, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
Sleep timer?
Sleep Timer option is available in remote only.
Aug 10, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sylvania tv input channel with dishnetwork remote
The remote control has a "Game" button, which is how you select the external input. Since you don't have a remote you can select game mode via the front panel Menu button:
1) Press the MENU button so that the menu display appears on the TV screen.
2) Press the VOL(ume) ▲ button so that "PICTURE" is selected.
3) Select the feature you wish to adjust with the CH(annel) ▲ or ▼ button and adjust it with the VOL(ume) ▲ or ▼ button.
GAME MODE: Set to the most suitable position for TV
GAME. [+] : ON [ - ] : OFF
This will place your TV into Game mode and use the front panel video/audio jacks.
Here is a link to download the user guide: http://www.sylvaniaconsumerelectronics.com/support/manual/index.aspx
Just enter your model number.
Please let me know if you have any questions.
Good Luck!
Mar 21, 2008 | Sylvania 6427TE 27" TV
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Dec 18, 2007 | Televison & Video
Sylvania 6432td 32" screen
You have to choose the right INPUT on your TV where your DVD player was connected. If your using the Yellow/Red/White cable from your DVD player you need to choose on your TV the input Example Video1 Video2, etc... If your using the COAX,(like cable wire) Put your TV on Channel 3 or 4. Hope this may help you. Please post the outcome, if you need further help. Is this TV is a COMBO?
Aug 13, 2007 | Sylvania 6427TE 27" TV
Sylvania 6432TE 32" TV Logo
333 people viewed this question
Top Sylvania Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
