Question about Champion International CPE 1000Watt TwoStroke Generator
Champion generater. It seems fuel pump is not pumping the gas . what to do?
Posted by mnaka on
henrys9371
    New Friend:
  • 3 Answers
First start small Check to see if there is any clogs in the line also check the fuel filter if the pump is broken go to google and type the model number in and that should bring up everything about that and possibly help you find parts for it
Posted on Mar 10, 2011
Bad gas champion 6800 generator
You need to:
1) replace the fuel in the tank
2) Remove the petcock and clean filter located on top
3) Rinse out tank with clean fuel
4) Clean the carb (replacement carb or carb rebuild kit might be required if damaged by ethanol in fuel)
5) Put it all back together and run the generator.
If you do need a carb or carb repair kit you can purchase them on our website:
http://www.generatorguru.com/champion
Nov 27, 2016 | Electrical Supplies
How do I get gas cap off?
try applying the pressure with water pump pliers if you have the room to work with them around cap
Jun 28, 2014 | Electrical Supplies
Onan generator
When you say no fuel, are you indication the fuel pump has no fuel from the vehicle? if so the pickup tube in the tank should be looked at. If you have fuel at the pump inlet, and the pump makes a load clatter whilst priming check by installing a cheap clear gas fuel filter between the pump out and the carb, run the gen to see if the carb is been starved of fuel, if so replace the fuel pump. Anothe rpoint make sure it is an OEM pump as they are low pressure and an automotive fuel pump is too much pressure and can lock the carb and cause dangerous leaks
May 24, 2013 | Onan Microquiet 3600 & 4000 Generator
My Champion 6.5HP Generator has a gas leak under the gas tank. The gas shut off valve is missing a rivet (one of two). I've got it unscrewed but am not sure how to get a replacement part. I have the...
They have a website at http://www.championpowerequipment.com. Click "support" and they tell you "If you need to order a part please call our tech support line. Our professionally trained technicians will be able to assist with placing orders. Orders ship within 1 business day - orders received before 2:00 PM (PST) will be shipped same day." The number is 1-877-338-0999. They also have many service bulletins thee thay will help solve many problems.
Apr 23, 2011 | Champion International Champion Power...
Champion International CPE 1000Watt TwoStroke Generator Logo
446 people viewed this question
Top Champion International Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you a Champion International Electrical Supply Expert? Answer questions, earn points and help others
