Cell Phones Logo
Anonymous Posted on Mar 10, 2011
I have Samsung Galaxy 5 GT-15503. Android 2.1. After full charge if I use it ,WI-Fi enable. Battery does not more than 2 hours. If Wi-Fi disabled battery last long. Why??
Anonymous
Level 1:
  • Contributor 326 Answers
  • Posted on Mar 10, 2011
Anonymous
Contributor
Level 1:
Answers
326
Questions
0
Helped
82793
Points
83
Wi-fi has been known to eat up the battery life on ALL devices it's on.
That's just the way it functions.
If you really want to save battery on your phone, disable wireless, bluetooth and 4G connections you may have, dim the screen to it's lowest setting and change the display timeout to a very low time.
rajat arora
Level 2:
  • Expert 136 Answers
rajat arora
Expert
Level 2:
Answers
136
Questions
0
Helped
29108
Points
285
Because when you use wifi it requires to get on large bandwith and hence exert more power thus battery provides you less backup
1helpful
I connected the phone to my wifi. But it wont go to any websites or mail etc.
Hi Shiela
Try the following as sometimes it's a simple setting missed..
Solution-1
On your phone under Settings>> WiFi >> Hold the Name of Your Network >> Now Click on Forgot Network.
Now reboot the phone & modem/router and try to connect the Wi-Fi again.
Solution-2
Pull out the phone battery while it is working & re-install after 30 second. Phone will reboot again now try to connect to network and check internet connectivity.
Solution-3
You can browse to Settings>> WiFi >> then press left menu key & Click on Advanced. Now check that Wi-Fi timer is not off. If Wi-Fi Timer is on then turn it off.
Now disable Wi-Fi & again enable it. Now check the connectivity on Android.
Solution -4 (Important)
Update your phone, Modem& Wi-Fi Router time and date to match the internet provider time and date. This is very important because 2 out of 10 cases are because of this issue.
Solution-5
Check the Internet connectivity after disabling the antivirus & mobile data.
May 01, 2016 • Cell Phones
I need a download manual.
PDF]User Manual Manua - Verizon Wireless
cache.vzw.com/multimedia/mim/...galaxy_tab2/galaxytab2_manual.pdf
relating to the SAMSUNG Galaxy Tab, including but not limited to, ... network solutions selected by the software provider, solution provider or user. ..... 2. Push the 4G LTE SIM Card in gently to release the lock. 3. Carefully slide the 4G LTE SIM ...
Support - Wi-Fi Tabs GT-P3113 ' Samsung Galaxy Tab
www.samsung.com > ... > Galaxy Tab > Wi-Fi Tabs
Samsung ElectronicsVisit Samsung today for Samsung Galaxy Tab® 2 7.0 (Wi-Fi), 8GB. You'll find ... Manuals. User Manual ver.1.0 (EN, 4.95 MB). Jan 29, 2015. Download (pdf)
Support - Wi-Fi Tabs GT-P5113 ' Samsung Galaxy Tab
My wifi stop working,i dont know why???
Solutions to Common Android WI-Fi ProblemsFriends of mine who use an Android come over to me usually with problems related to their devices' Wi-Fi connectivity. Moreover, it's not a single isolated issue. There are all kinds of them they bring up. I usually fix their problem after few troubleshoots but today while I was fixing a problem on my device, I realized that it could happen to any one - even to my readers on Guiding Tech. Hence we are going to discuss four of the most common Android Wi-Fi problems and see the probable causes and solutions to them.
Android Cannot Scan a Wi-Fi Network Reason
There may be two reasons as to why your Android cannot scan a network automatically. The first reason may be that the network you are trying to connect to could be Ad-Hoc in nature. As most of the Android phones are not configured to work on Ad-Hoc networks but on access points, they don't scan them.
The second reason may be that the Wi-Fi network you are trying to connect to might be hidden for security reasons.
Solution
By default, Android does not support Ad-Hoc Wi-Fi network but many developers patch the wpa_supplicant file on Android in order for them to work. If you do a quick Google search you will be able to find if there's a fix available for your device but the fix can only be performed on a rooted phone. Furthermore, don't forget to back up your original wpa_supplicant file if at all your phones goes into foreclose or boot loops.
If the problem is with the hidden network, you can try to add the network manually. In Android Wi-Fi settings open menu and tap to add a network manually. You must enter the correct SSID and authentication type and password in order to connect to the network. If both the credentials are correct, the Android phone will be able to connect to the network.
Wi-Fi Keeps Disconnecting Frequently Reason
The most obvious reason for the problem may be with the Wi-Fi Sleep Policy which disconnects your Wi-Fi every time your Android goes to sleep to save your battery's juice.
Solution
To manage Wi-Fi Sleep Policy, open Advance Wi-Fi settings on Android and tap the option Keep Wi-Fi on during sleep. Here, check the option Always to enjoy an uninterrupted connectivity, but you will have to compensate it with your battery life.
If you are using any third-party app to save your battery, check if it's controlling your Wi-Fi and other radio services and configure accordingly.
Obtaining IP Address Infinite Loop Reason
I don't know the exact reason behind this, but it might be a bug in Android. I have seen many people getting this problem, and it gets kind of annoying when the problem does not gets fixed even after restarting the device.
Solution
First of all, you must restart your Wi-Fi router and see if that helps. Many people say that resetting the phone to factory state works but that's not an appropriate solution. Wi-Fi Fixer is an amazing Android app that can help you here. The app resets your Wi-Fi system files (same as when you reinstall the Wi-Fi drivers in Windows, or you disable and enable the Wi-Fi adapter) and services and helps you to connect to the network and obtain the IP address.
Solutions to Common Android Wi-Fi Problems
Ads by Google
    wifi-router.pngFriends of mine who use an Android come over to me usually with problems related to their devices' Wi-Fi connectivity. Moreover, it's not a single isolated issue. There are all kinds of them they bring up.
    Solution
    ad-network-manually.png If the problem is with the hidden network, you can try to add the network manually. In Android Wi-Fi settings open menu and tap to add a network manually. You must enter the correct SSID and authentication type and password in order to connect to the network. If both the credentials are correct, the Android phone will be able to connect to the network.
    Solution
    Ads by Google advanced-settings.pngkeep-wifi-on.png If you are using any third-party app to save your battery, check if it's controlling your Wi-Fi and other radio services and configure accordingly.
    Solution
    wifi-fixer.png If you know the range of IP address the router is broadcasting, you may configure your Android to use static IP address while connecting to the network.
    Can't Connect to Internet using Wi-Fi Reasons
    There may be several reasons as to why you are not able to connect to the internet even when you are connected to the Wi-Fi. The reasons may be:
    • The router is not broadcasting internet services.
    • The IP address or the gateway is wrong.
    • Problem with the DNS settings.
    Solutions
    You may use another device to check if the router is actually broadcasting internet. Also you can configure the IP address, the gateway and DNS manually to connect as their might be problems with DHCP.
    Conclusion These are pretty much most of the Android problems one might encounter on his device and the probable solution one can try to fix the problem. I don't guarantee that you will fix the problem but it's a good start nonetheless. And most of the solutions should work actually.
Thanks .
Sep 03, 2013 • Cell Phones
Can get my archos 5 to conect to my android phone
If you mean to connect your Archos to your Android device through Wi-Fi, than, yes, you can! But, only if your android device supports the tethering feature. For example if you have an Android 2.2 (Froyo) device than you go to Settings->>Wireless & networks->>Tethering & portable hotspot and tap "Portable Wi-Fi hotspot". From the Archos, go to the the Wi-Fi settings and connect to the network you've just created. If you do not have the tethering option available, you should find out if your carrier or device manufacturer has an update for the device. Hope it helps!
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
