I have a Zenih Allego table type stereo with 8 track, radio & turntable, but it has NO cartridge at all - just wires from the needle arm. It's supposed to play 78s, how can I find out which cartridge and needle I should be hunting down?
Posted by don7mm on
Jacob Paul
  • 635 Answers
You will need a very old type of cartridge called CERAMIC CARTRIDGE or CRYSTAL CARTRIDGE. It has been discontinued. Today's Hi-Fi use magnetic cartridge. Check out this link below
http://www.kabusa.com/frameset.htm?/phoncart.htm
Posted on Mar 10, 2011
Can my turntable be adjusted
Jody, the arm the needle is on, usually adjustable with a dial on the end that can lighten, or put more weight on needle to help it track better on records. Other then that, the belts normally are changed to address slow speed issues. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Jensen JTA 220 Instruction Manual Page 2
http://audio.manualsonline.com/manuals/mfg/jensen/jta220.html
How To Calibrate Your Turntable For the Best Possible Sound
How to Adjust Tracking Force
Apr 09, 2016 | Jensen Jta-220 3-speed Stereo Turntable...
I need a new needle- where can I get it- part number please.
Copy down the brand and model of the turntable and go to your local stereo shop. Radio Shack used to carry these, too - but I don't know if they do anymore. Sometimes the cartridge needs to be replaces as well. That will be the rectangular piece the needle is inserted to on the underside of the tone arm. If your see a name and number on it - write it down. The needle can be easy to replace - the cartridge however is a little more involved.
Sep 10, 2015 | Audio Players & Recorders
Does this model panasonic fm/am radio stero phone need a cartage for the needle.
As it was purchased second-hand, I would replace the cartridge and stylus with a new one anyway. You can put the model number of the cartridge (found on it) into Google search. That should come up with the right one. You can basically fit most types of cartridge, as long as the you get the right type. IE: A magnetic one if the unit has a cartridge pre-amp built into. Or the Ceramic type etc if it hasn't.
Aug 30, 2015 | Panasonic Audio Players & Recorders
Kenwood kax-38 amp. distorted sound from turnatable if connected to the phono rca plugs, but ok if connected to the CD rca plugs.
The phono sockets for this are at different line levels for that reason. Phone is for the turntable depending on the type. If it is a later model stereo and an older model cheaper turntable, it uses an older type of needle cartridge called ceramic. The signal output of it is higher than the later magnetic cartridges and may need a preamp (radio shack) to match the line level signal, allowing it to clear the distortion. If this scenario were reversed, using an older cheaper stereo with a later, better quality turntable, the opposite would happen. (signal to low) This preamp would amplify the input. I think you need what is called a matcher to lower the input signal instead of the preamp. I've seen these at radioshack. BTW, the CD input doesn't distort as much because a cd player puts out a high signal and the amp is matched to accept it.
Dec 03, 2013 | SR-10 Adpater Cable - Kenwood Twin-Pin...
JVC auto return turntABLE - mODEL al-a95bk
when you said "no sound enough to enjoy listening" did you mean that you could hear something coming thru the speakers, but it isn't loud enough? if so, you may be plugging the turntable into a "ceramic" phono input on your stereo. it may be that your stereo doesn't have a pre-amplifier on the phono inputs. Ceramic tonearm cartridges (the part that holds the stylus - which you may call the needle) have enough output level to drive an amplifier. if your cartridge is magnetic, the output is very low compared o the ceramic. the trade off is that magnetic cartridges have a much wider dynamic range than the ceramic, and when properly pre-amplified, sound MUCH better than a ceramic unit. you can probably find a separate pre-amp at radio shack (i know they sold them several years ago). you plug the turntable into the inputs of the pre-amp, then plug the pre-amps output into your stereo. hope this helps.
Dec 19, 2011 | Audio Players & Recorders
My turn table works properly but its volume is too low thu the amp is perfect. the needls are new too
Look it can either be one of 3 things. (1) Cartridge knackered. 2 Internal pre-amp in turntable. 3 Cartridge Pre-amp in Main amp connected to it.
To solve (1) disconnect all wires to cartridge. With the turntable connected to main amp - touch each channel wire (that connects to cart) with your finger. If you hear a decent buzz the cart has gone. A weak buzz and the other two could be still to blame.
Remember all functions on your main amp can work fine, but that pre-amp for the cartridge (often a single IC) can be dead or weak.
Jun 06, 2010 | Technics SL-1210 Turntable
My mother has a 40 year old RCA console stereo. The mechanism at the end of the arm that holds the needle is an empty shell with a few wires showing. I was able to purchase a new needle, but I may need an...
I can't see anyone still making a 40 year old turntable arm. You could get a replacement cartridge for it. You might need either a ceramic or magnetic one, depending on the pre-amp of the RCA.
Mar 12, 2010 | Audio Players & Recorders
Record player - sound only plays out of one speaker
Your tracking and anti-skate are not set correctly.
If you have the manual for this unit, it should have directions for setting these.
Sep 11, 2009 | Audio Players & Recorders
Replace needle on old Admiral turntable
what type of needle does a gemini turntable need?
Apr 14, 2009 | Audio Players & Recorders
74 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
