I have an '04 Outlander and the manual slap stick stopped working. I also noticed the Drive light was not on when in auto drive. This is a common problem with this model and a relatively easy fix. Tools you will need are a small flat head and medium cross head scredriver, solder gun and electronic grade solder, small heat shrink tubing. Remove the entire center console - start at the rear by removing the 4 philips screws in the center arm rest compartment, remove the cover plate underneath the hand brake and the 2 side panels on either side at the front. Remove the shift knob (2 screws behind the small cover plate on the front of the knob - remove with small flat head screwdriver). Remove all remaining screws and the rear section, then slide the center section over the handbrake followed by the front section.
You will see a small switch on the shift lever with 3 wires (Black, Blue and Red). Most likely one or more have become detached, at this point it is best to unsolder any that are still attached because they will likely break in the near future! Remove any old solder and wire from the 3 contacts with the solder gun on the switch and tin each with fresh solder. Strip about 1/8" on each of the 3 wires and tin each with solder. Slide about 1/2-3/4" of the heat shrink tubing onto each wire. Solder the wires back to the swtich in this order:
Black - top
Blue - center
Red - bottom
Start at the top and work down, and after soldering each slide the heat shrink tubing over the solder joint and shrink by applying the solder gun - this will provide better mechanical support and help prevent future breakage.
Reassemble the center console in the reverse order of removal - make sure you have no screws left over!!
Good luck - hope this helps.
SOURCE: Mitsubishi Outlander 2003 cooling fan issue
I had the same problem. I took my 2003 outlander into the mits. dealership and they told me there was a factory recall for some sort of relay or something for the cooling fan. they fixed it no charge. hope this helps.
darryl
SOURCE: mitsubishi outlander 2003 air conditioner- works
check air conditioner compressor fuse or relay.if all is good.you have a open compressor clutch coil or a bad compressor.also check compressor clutch wire.
SOURCE: mitsubishi outlander cooling fans not operating
there is a recall on the cooling fan controller you can call a local mitsu dealer tell them your vin to see if you are covered under the recall
There is a Recall to replace your cooling fan module because of this concern.
Open your hood and look at the black box bolted to your radiator fan by the battery. If it does not have a green dot on it, you have not had the replacement fan module installed.
Contact your local dealer with your VIN handy to verify the recall has not been done and to schedule an appointment.
If the recall has been done, verify if you have power coming out of the module to the fans, as the fans do burn out eventually.... but rarely both at once.
SOURCE: transmission problem stuck in sport shift mode
I also have a 2009 Outlander Sportronic transmission with a V6 engine.
Bought it this summer ... transmission appeared fine but seemed to automatically slow down the vehicle using the engines compression whenever I let go of the gas pedal.
Now that the cold weather is upon us here in Canada, whenever I accelarate normally (not like a teenager) the transmission takes quite a bit of time to shift into second... If I rev up the engine (quick take off) it seems to help but the shifting of gears is not as smooth as I would expect it (mildly slips and kicks into second)...
The worst is when come to a complete stop ... then the transmission kicks coming down from the higher gears???
I read somewhere that this is because this transmission is a CVT type and is learning my driving habits in order to adjust itself so the vehicle becomes more fuel efficient... Not sure but if the trany is computer controlled then it must be poorly writen program...
I'm taking the car in to the dealer and will write back on the diagnostic they give me ...
The shifter has a sensor (switch) located under the center conslole and two wires or more are connected there to sense the shifter position. Very common for these wires to be broken from stress during normal use. Remove the cover and check the wires. If you are marginally mechanical it is a simple fix. Attach the wires back to their original points and your sport shift and lights should be normal. I think new wire ends (nothing special) were needed.
