Question about Philips 32PF7421D 32 in. LCD HDTV
Where is my cable output on my Philips TV 32PF7321D/37. How do I get cable on my TV I cannot find a cable output! please help
Posted by aichastern on
Anonymous
    New Friend:
    Problem Solver:
  • 7 Answers
Your output cable is in the back of your t.v. there is a color designated on its hole then you have to buy a a cable in any electronic shop like components cable or hdmi cable try to read the back panel of your tv
Posted on Mar 10, 2011
    Top Expert:
  • Philips Master
  • 76,544 Answers
Hello
Using HDMI
Connect RF cable from wall to input at back of the cable box.
Set output switch on set-top box to CH 3 or 4 and tune TV to same
channel.
In some cases, cable box will automatically tune to channel 3 or 4. Just change
channels until picture appears.
Connect cable box to TV using HDMI cable.
Note : If the accessory device has DVI output only, use a DVI to HDMI adapter
cable to connect to the HDMI connector. You need to also connect the audio
cable to L and R AUDIO jacks. Next, go to Menu => Setup => Source
=> Analog Audio In => and select HDMI.
Using RF Cable
Connect RF cable from wall to input at the back of the cable box.
Use second RF to connect the cable box to the TV's antenna input.
The volume controls on both my remote and my Philips flat HDTV 37PF7320A 37." How do I fix it?
Read your Philips setup info that came with your tv very carefully and also if applicable read your cable box setup info very carefully then set every thing up like it says also check tv audio menu and make sure the audio is set to on
Sep 13, 2014 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips md#32PT9100D/37 will not turn on only
Hi
Your tv set may have a short circuit both in the power supply and horizontal output stage. The first approach I suggest is to check the rectifier fast diode in the line supply (90/100V) for short. This model is prone to burn this component and may be associated with some problem in the horizontal output or even in the RGB output.
I would like to point out that this task require a technician as should be supported with a schematic of this model.
If this is helpful, I shall be glad.
Sully
Sep 22, 2013 | Philips Televison & Video
I would like to hook up my philips hts3544 to my hdtv. i have a satelite receiver in between . i cant always get the hts to provide volume for my tv . can you advise me how to
Manuals answer most of those types of questions.
SAT IN BETWEEN THEM? WHY?? HOW? Treat the SAT as an A/V audio source.
Provide "volume" for the TV?? What's that mean? No sound or no control of it?
Most TV's have multiple Video inputs. The SAT should go STRAIGHT to it. The digital audio, if available on a coaxial digital output, SHOULD be run to the HTS's coax digital input.
The TV speakers will never be under control of the HTS. TheTV volume would handle that end. What's the point? Are the TV speakers BETTER?
The HDMI cable CAN carry the audio to it. As the manual says,
"Make sure that the audio output setting is not turned off. See 'Setup Menu Options - { Audio Setup Page -
HDMI Audio }' for details."
Go to http://www.p4c.philips.com/files/h/ and drill down to the HTS3544/37 directory for the manual. The alpha directories are slow loading. Be patient.
Jun 09, 2011 | Philips HTS3544/37 Theater System
My tv (32PF321D/37) won't turn on and the power light is flashing red six times, pausing, then doing it again. Any ideas?
Check bulging capacitors in power supply that causing 6 red LED flashes. Replace them and fix the problem. philips-32pfl5322d-37-04.jpg?w=770
Feb 01, 2011 | Philips 32PF7321D 32 in. LCD Television
After turning of the TV for a few minutes, it won't turn ON. The power LED turns green for a second and then becomes red and flashes, Philips Model 32PF7321D/37
grodmx74, You or electronics technician will need to find the "thermally-intermittant-hair-line-fracture" of a component soldered to the switch-mode-power-supply printed circuit board with aid of large magnifing glass or use a 10x or 20x inspection microscope, and then resolder the connection. 12fixlouie
Apr 02, 2010 | Philips 32PF7321D 32 in. LCD Television
Won't record..
try swapping the scart lead to the second AV port on the player sometimes 1 is input and the other output run your tv cable direct to the player and scart to tv hope this helps
May 15, 2009 | Philips Magnavox DVD/VCR Dual Player
Philips 42PF7220A/37 Chassis Number BP2.3U
I think its something on the picture frame board or on the line output board. I would sway to the line output simply because I think but not sure that error code is linked to the line output stage plus when you unplugged the cable the voltage seems within parameters. Good luck.
Aug 04, 2008 | Philips 42PF7220A 42 in. Plasma Television
Please help me!!
There are a few possibilities.
1)You can connect a red and white AV cable (or the red and white portion of a red, white and yellow cable) from the TV Audio OUTPUT to the "Audio In/TV" portion of the HTS (NOTE: Many TV's do not have an Audio OUTPUT).
2)You can connect a red and white AV cable (or the red and white portion of a red, white and yellow cable) from the Audio OUTPUT of your cable or satellite box to the "Audio In/TV" portion of the HTS.
Note: Using a red and white cable may not give you sound on all 5 speakers.
3)Get a digital audio or SPDIF cable and run it from the TV, Cable or Satellite Box's Digital Audio OUT to the "DIGITAL IN" of the HTS. This will give you the best sound quality. When using this (or any of the other) type of connection, press SURR until you get sound from all 5 speakers.
Also, the manual can be obtained from www.usasupport.philips.com
-Tha Mp3 Doctor
Jan 25, 2008 | Philips HTS3440/37 System
WIRE ELIMNATION
For the TV:
For the Xbox, try hooking a red/white audio cable from the Xbox into the Audio IN/AUX on the back of the HTS, and then switching the source on the home theater to AUX.
-Tha Mp3 Doctor
Jan 06, 2008 | Philips HTS-6500/37 System
Hooking dvd player to tv
check if your dvd video output is switched to the svideo or RGB and make sure it is switched to the output youare connecting video cable .
Dec 31, 2007 | Philips 32PT6441/37 32" TV
Philips 32PF7421D 32 in. LCD HDTV Logo
505 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
