Suggest the Power Supply took a 'hit' from the storm. Hopefully this is all that received the power surge.
Surge protectors are a necessary item, but in reality it takes an Expensive surge protector, for defense against a lightning storm, and even that isn't a sure bet.
(Lightning strikes can produce over a Million volts)
Also, I have had three surge protectors where just THAT receptacle was bad.
"Hmmmm, surge protector power on LED is lit. Printer has power, monitor has power, and router has power. Surge protector must be good."
NOT.
Just THE receptacle the computer was plugged into was bad.
Past this test, I would suggest diagnosing the Power Supply.
A) Test the Power Supply voltages
B) Use a KNOWN to be Good, Compatible power supply, for a test unit.
C) Buy a power supply, and replace it.
Granted, not a professional approach, and could result in a waste of money.
Some do approach repair in this manner, however.
Going backwards.
C) The Gateway 504GR desktop computer uses an ATX style of power supply, and is rated at a maximum Wattage rating of 300 Watts.
(ATX case is approximately 6 inches Long, 6 inches Wide, and 3-1/2 inches Tall)
Gateway Support > 504GR desktop computer > Support Documents main page,
http://support.gateway.com/s/PC/R/3724/4365nv.shtmlIf you Left-click on - Components, you will see a list of components used in the 504GR.
Scroll down to the heading - Power Supplies
Left-click on the blue -
102015 - 300 Watt Power Supply, heading.
It's just a generic ATX power supply with a,
1) 24-pin ATX main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain242) 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4[ Power for the Intel Pentium 4 processor. Plugs into the motherboard ]
3) (1) SATA power cable
http://www.playtool.com/pages/psuconnectors/connectors.html#sata[Power for the SATA harddrive ]
4) At least two 4-pin Peripheral power cables,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral[Power for the CD drive, and the DVD drive ]
This is just one example of a decent, reliable, economical Power Supply, that will fit the bill,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1389575&CatId=1078B) The above explains the minimum Wattage needed for the test unit, the size, and shape of the case, and the needed power cables, in case there is a power supply around to use for a test unit.
(Some have an older unused computer sitting in a closet, or what have you. The computer can be temporarily cannibalized for the power supply)
1) That SMPS (Switched-Mode Power Supply) puts out three DC voltages.
A) 3.3 Volts
B) 5 Volts
C) 12 Volts
(Two C cell flashlight batteries produce 3 Volts DC)
The test is done for the 12 Volt power rail.
ALL Yellow wires in the various power cables, are 12 Volt wires.
They all go back to one 12 Volt power rail inside the Power Supply.
[Orange insulated wires are 3.3 Volts.
Red wires are 5 Volts ]
11 to 13 Volts indicates a good Power Supply.
Less than 11 Volts means it's time to replace.
You can use a multimeter to check the 12 Volt power rail, or a power supply tester.
One example of a power supply tester,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5250576&CatId=5471An economical multimeter good enough for this test, can be purchased from $5 to $12.
The Power Supply is unplugged from power.
The Positive (Red) probe lead of the multimeter, is connected to ANY Yellow wire.
The Negative (Black) probe lead is connected to ANY Black wire.
(ALL Black wires are Ground wires. They all go back to one central Ground source inside the PSU.
{Power Supply Unit. Another term for Power Supply. Also another term for the SMPS, used in personal computers)
To reply just Left-click on Comment. (Believe upper right of your page )
