Question about Texas Instruments TI-83 Plus Calculator
My TI-83 calculator is giving me answers that are wrong by about .08 to .15 I am positive that i am entering the equations in the right way. I have the answers to the problems so i know that the answers its giving me are off by a small amount. The calculator is also reset, set to degree, and float, as i saw those were some of the fixes google brought up. Thank you.
Posted by devinwhitema on
  • kakima Mar 09, 2011
    Could you post an example or two? Without knowing what you're trying to do, it's all but impossible to tell what's wrong.
theboss6424
    New Friend:
  • 61 Answers
Try reseting your calculator if needed, and sometimes answers can be off because the calculator sometimes is so precise you answers may be rounded.
Posted on Mar 10, 2011
TI-83 Plus ( finding linear regression) gives wrong y-intercept (b=) value sometimes. Please tell me why?
I get the same answer. Is b wrong? When I do it in Excel I get b= -2E+06, which is -1 797 322.99 rounded to the millions, in scientific notation.
Let me know if you have any questions.
Good luck,
Paul
Jan 24, 2016 | Texas Instruments TI-83 Plus Calculator
Equations
You can't simply enter 7x+9=30 into the calculator, there is a way to calculate what the x is but its been a few years since I've done these..
Oct 03, 2008 | Texas Instruments TI-83 Plus Calculator
Solve() gives me wrong answer. -20^2=12^2+2X(-5-3). The answer is -16, But my TI-89 is giving me 34 during the solve funtion. my TI-83 is also giving me -20^2=-400 not 400.
Enter the first term as (-20^2), not as -20^2. Without the parentheses the calculator interprets it as
-(20^2), which is not what you want.
Also, make sure you use the (-) key just to the right of the decimal point and not the - key.
Aug 31, 2011 | Texas Instruments TI-89 Calculator
My TI-83 plus seems to give me the wrong answer if I type in the problem: 1400/(60*24) The answer should be 1, but I keep getting .9722222. I don't understand why it keeps giving me the wrong...
That is the correct answer. 60 multiplied by 24 is 1440. 1400 divided by 1440 is a number slightly smaller than 1.
Are you sure the problem isn't 1440/(60*24)?
Jun 22, 2011 | Texas Instruments TI-83 Plus Calculator
How do I set up graph lines
in order to give the calculator a function to graph, you will want to enter the y= window by pressing the top left most button on the calculator. nintenman1.gif a menu similar to the one above will open, wherein you can enter an equation for the calculator to graph, such as (x^2-2). On the ti-83 itself, you can enter up to 9 equations to be graphed at once. after that, you may want to go to the window menu, where you can set the dimensions of the graphing plane in both the x row and y column. to view the graph, press the top right most button on the device.
hope that helps :)
Mar 29, 2011 | Texas Instruments TI-83 Plus Calculator
I have a very old Texas TI-83 calculator, and I have not used it in years and have lost instruction manual. How do I change the setting to get the calculator to work out equations to more than two decimal...
Press MODE to enter the mode editor. Scroll to the second line and select FLOAT or a larger number of digits than the 2 it appears to be in now.
You can download a Guidebook from http://education.ti.com
May 18, 2010 | Texas Instruments TI-83 Plus Calculator
TI 83
Yes you can use it, here is the formula: Y= V(t+ (i/c))^(tc) V=amount put in, t=time, i=intrest rate, c= amount of times it is compounded.
(I know this because I have a TI-83 calculator)
Mar 27, 2009 | Texas Instruments TI-83+ Graphing...
Graph feature is not working on TI-83
you have one of your stat plots on that is what is messing it up. So either turn off the stat plots. Or just reset your calculator. hit 2nd then the plus (+) key then 7 then 1 then 2. Good luck
Nov 12, 2008 | Texas Instruments TI-83 Plus Calculator
How to use the texas instruments ti 83 plus
Srry my friend the ti 83 is no magnificent Ti-89. meaning: you have to solve it yourself. There is a method for graphing though. Set the equation equal to zero and then plug the stuff on the other side of the equation into a graph by pressing y= and then typing it in. Then hit graph. Wait for the graph and then hit 2nd calc and select zeros. Bring your cursor using hte arrow keys close to where the line hits the x axis and press enter and then do the same except to the right of that point and then press enter twice and it will display the y which should be the answer
There are quadratic formulas for calculators programmed in tibasic for the calc but other than that there is no way to solve it
Apr 27, 2008 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
420 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Paul Bade
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
