Question about Bosch Drills
I have a 36v ac 3640 cv charger with a burnt out thermistor i need to know rating for the thrmistor marked up on pcb as r2
Lee Wright
    New Friend:
  • 19 Answers
Hi mate i know its 2 years over later if u have red flashing led this normally fixes fault..replace R2 ON CHARGER,
www.uk.farnel.com then search this,,,:- B57236S500M
Posted on Feb 17, 2013
Hello, i have a sony ke-42xbr900 and the box flashes 9 times (red light) and the tv flashes 6 times (red light), i changed the G board (power supply) from shop jimmy and still have the exact same prob
The R1 or R2 probably the problem. visually inspect each PCB for blown or burnt parts. R1 pt# A1401606B R2 Pt# A1401891B, but these don't appear to available anymore. I have checked with tristate, encompass, shopjimmy & thetvguys
Dec 31, 2014 | Sony Televison & Video
My power star w7 inverter charger wont charge off genset
there are things you would need to check
1, Does your inverter charge over any other power source?
if no, your inverter input power source has a problem
if yes , then
a, check the input voltage/frequency rating of your inverter then compare it to the output rating of your gen set
i believe there would be a difference between them
use a multimeter tester{ac}
inverters reject strange voltages or high voltage to protect itself from damage
May 29, 2014 | Electronics - Others
I am in Canada and I cannot get a Black & Decker 36V charger which is LCS36. The B & D 36V battery looks identical to the Dewalt 36V battery but I cannot be positive. Do you know if the B & D LBXR36...
What I do know is that some NiCd 12V Black decker batteries that look similar to the dewalt ones they are charged by the dewalt charger.
But there are 12V Nicd black and decker batteries that they can not be charged due to an extra plastic edge that does not allow to be charged by the dewalt charger.
Now if you do have the dewalt lithium 36V charger and if the black and decker battery is a 36V lithium one and can not be charged due to a plastic edge then I would recommend to risk to destroy the plastic edge in order the black and decker battery to be charged.
Sep 25, 2013 | Dewalt Black & Decker / DC9360 36V Battery
My photocopy macheni canon ir 4570 keeps on giving the error code e0001-0002
Fuser temperature too high.
Check AC driver board, shorted thermistor. Replace The Main Power Supply PCB Assembly (The part number FM2-0260-000).
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Dec 31, 2012 | Office Equipment & Supplies
Ir7095 error code E000004-0001
If you have more than 200 000 prints need to be replaced: Fixing assembly 230 V......... FM2-0174
Inspect thermistor and switch on FIXING UPPER FRAME ASSEMBLY
Oct 09, 2012 | Office Equipment & Supplies
How do u know if your ryobi charger is burnt out
Checked the output supply of the charger using tester, in using tester you must need to know the output supply if it is in dc(direct current) or AC(alternating current), then select it from the selector of the tester if there is a reading then that good,make sure to know the supply of your ryobi charger by checking it from the specs of charger itself.. If the reading is accurate then the charger is good if not then the charger is defective then replace a new one. Hope this simple solution could help you to solve your problem. Mam/ Sir don't forget me to rate me up I really appreciate what Ratings you have given to me. Thanks a lot and God Bless.
Jun 21, 2011 | Drills
Hello, My Canon CLC 900 is showing E061 after it starts up? Any suggestions?
E000–0061, 0071, 0081
1) Clear ‘E000’. Is ‘E000’ indicated immediately after the power
switch is turned on?
• Be sure to turn off the power switch as soon as you have made the
check.
NO: Go to step 3.
Oil thermistor (TH5), Oil heater thermistor (TH6; short circuit), DC controller PCB
2) Turn off the power switch, and disconnect J6019 from J2209 on the
DC controller PCB. Measure the resistance between a and b of the
following table in reference to the detail code; is it 1 Kω?
Code a b
0061/0081 J6019-B5 J6019-B6
0071/0081 J6019-B10 J6019-B11
AC driver PCB
DC controller PCB
3) Replace the AC driver PCB. Is the problem corrected?
YES: End.
NO: Replace the DC controller PCB.
Oct 17, 2009 | Canon CLC-700 Copier
Canon Copier NP 1020 - error code E0
pretty much the same, the codes are good for several models not just one.
you need to find the other numbers to know exactly which code it is, press the start or stop key to see it display the other #'s.
fuser is on the left side if you replace the parts might as well replace the claws and oil roller.
"E000" Heater lamp, Thermistor, DC controller "E001" Heater lamp, DC power supply / AC Driver circuit board, Thermistor, DC controller. "E010" Main motor clock sensor, DC controller PCB, Main motor, DC power supply / AC Driver circuit board
Sep 16, 2008 | Canon Office Equipment & Supplies
De walt de9118 charger
when charger is plug in to ac it will blink once.normal voltage out for the unit in between 36v to 55 volt. the reading u have is normal.
Aug 07, 2008 | Dewalt 7.2-18.0 Volt One Hour Charger
Drills Logo
417 people viewed this question
Top Bosch Drills Experts
Paul Carew
Muntejaya Ginting
Muntejaya Ginting
Are you a Bosch Drill Expert? Answer questions, earn points and help others
