Garden Logo
Posted on Mar 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a pontec filter that i know nothing about and i can't find any info on it. It is a round canister with two hose conections on top the lid, one says in the other says out. I think it is biological cause it has two media filters and a circled screen on the inside. any info would be helpfull. thank you
Anonymous
Level 2:
New Friend:
  • Expert 56 Answers
  • Posted on Mar 12, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
56
Questions
0
Helped
24777
Points
126
Well first off lets get some information about the filter. First calculating gallons per hour, this is easier than most people think. Fill a basin, bucket or tub with water then get a 5 gal bucket or something suitable to measure a set amount of water. Time how long it takes and calculate up to your per hour flow rate.
It does sound like a biological type so it is simply a matter of adding your preferred media, prime and go. I would suggest when cleaning the filter media trade off between cleaning your filter pads and bio-media to preserve your bacteria.
I need a secondary air management system diagram for an 87 cadillac deville. the diagram i need is the one where there is a filter gm pn:a224c is located in the fresh air inlet hose going to the air pump.
The A.I.R. (Air Injection Reaction) System was included on California-emission equipped vehicles. The system is designed to provide additional oxygen to continue the combustion process after the exhaust gases leave the combustion chamber. The system begins with the outside air inlet, which is a short, L-shaped open-ended rubber hose running from the lower front passenger fender well into the canister. The black plastic round canister is located in the front passenger-side engine compartment, adjacent to the EECS (Evaporative Emission Control System) canister, which looks similiar, but the EECS canister has electrical connectors on the top. While the charcoal canister of the EECS is a sealed unit, the A.I.R. canister has a twist-off lid to access the disposable filter. The inlet hose goes into the canister, air then passes through the charcoal filter, and travels into the outlet hose (also made of black rubber), which then connects directly to a metal tube coming up the front of the engine. Please contact me if you need a diagram or photos.
My 1987 deville has been missing the intake hose that brings fresh air into the air pump. the hose before the inline filter is the part i need but can't determine if anything else is missing as w
Filter queen vac 2 years old suction poor cleaned hose canister and filter
Hi, Did you change both the cone and the filter on the top lid? If so, ther may be a leak in the machine breaking the air tight vacuum. When you put it together make sure its in properly and tight. Let me know if this does not help, I will look at something else. Chris
I am trying to replace the fuel filter on my 1999 Dodge Ram 24 valve Cummins engine. It looks like the lid of the housing canister for the fuel filter is fixed, so do I just remove the top center nut so...
You are correct. The nut on top of the canister is loosened and the canister drops down. First - disconnect the electrical pigtail for the water sensor (at the bottom of the canister. Second - turn the water fuel bleed valve (yellow) near the top front of the canister to control spillage when you do remove the canister. The new filter comes with new O ring seals. Moisten with claean diesel and install. Add clean diesel to the newly installed filter and you will have an easier start up.
How do you open the air filter container, when it looks sealed, i see no clamps or wing nuts, do i need to remove the top hose or something? also, the car will stall out when driving, i have had it to the...
It is a round filter in a canister. There is a tube that comes from the throttle body to the air filter housing. Loosen the clamp on the intake hose to the canister then pull the hose up inside you will see a nut or wing nut remove that then the lid comes up and remove the old filter. zdupo+7esmkf5debcbaaaawamqf1fqvk8glgiaaacabyauoqb4x0fcbaaaaaapqfxeqfg+grgiaaaaab6auiic4n0fcreaaaaapabxeqxf+wriigaaaab4aoiicor3fcrfaaaaapaaxeuufo8riisaaaaa4agiiygo3lcqfweaaadaaxaxuvc8ryauagaaaiahic6iohhfqvweaaaaaa9axerb8b6cuagaaaaahoc4iilifqvxeqaaaaa8wacava7iigaaaaaaamhbxaqaaaaaaaaziisaaaaaaaagg4ulkcgokcgokcgokcgokcjs8v8bd5bxe3kc3xcaaaaasuvork5cyiia
2helpful
2answers
Vacuum sounds funny and doesn't have any suction.
I love the Dyson (DC07), but after 7 or 8 years it lost suction and needed some attention beyond filter cleaning. After much online research I found the few bits of advice that for me were the holy grail. After all of the standard stuff, clear clogs, clean filters etc..... In this order: 1) Remove & empty the canister, ***important****-leave the canister bottom lid open. 2) remove the three star screws at the top of the canister. It'll take a bit of pressure to pull the top up, there's a rubber seal. When you pull it up there will be a rod running down into the canister, leave it be, just pull up the top high enough to clear out any debris. 3) Put the top back on aligning the screws, when you lower it make sure the bottom of the rod engages with the hole at the bottom center of the canister, this is why you left the bottom lid open. Put the three star screws back in. 4) Turn the canister upside down, lid open, and keeping in mind this is thin plastic, gently tug upwards on the four fins that surround the bottom rubber seal. This part is held in by friction, so work your way around the four fins gently pulling until you work the ring they're connected to free. This will give you access to the inside of the canister. 5) remove the round perforated section by tugging upwards on it, set it aside with the fin part. 6) Take the canister to a laundry tub or large sink and holding it bottom up fill it with hot/warm water. Grasping the center section shake it vigorously and turn it upside down while shaking and a bunch of sh*t will come out. Repeat several times. 7) Dry thoroughly, you might use a hairdryer held to the center tube, but only if you can switch off the heat and use air only. Make sure its 200% dry, water will kill your machine 8) clean and replace the round perforated section 9) replace the fin section, I'd suggest pulling the round rubber part off of the fin part and setting it in place on the canister first, then follow with the plastic fin part. If you don't do it this way the rubber won't seat properly and the bottom lid won't close. 10) Close the lid, replace the canister, and staaaaaart suckin like it's brand new.
3answers
I have lost suction.....what do I do? -with the vacuum and the hose!
Its okay to unscrew where the hose is connect to the area close to the bottom, where the hose bends. That is where there is usually a ball of hair, dust, and whatever. Pull the hair ball out and also clean the roller.
4helpful
3answers
Lack of suction
you should check the round filter casing on theleft and the right side of machine to make sure they are snaped in right also the clear hose on the bottom sumtimes comes unhooked.
1helpful
3answers
My dyson seems to have lost suction?
If the usual clog clearing and filter cleaning doesn;t work-> I love the Dyson (DC07), but after 7 or 8 years it lost suction and needed some attention beyond filter cleaning. After much online research I found the few bits of advice that for me were the holy grail. After all of the standard stuff, clear clogs, clean filters etc..... In this order: 1) Remove & empty the canister, ***important****-leave the canister bottom lid open. 2) remove the three star screws at the top of the canister. It'll take a bit of pressure to pull the top up, there's a rubber seal. When you pull it up there will be a rod running down into the canister, leave it be, just pull up the top high enough to clear out any debris. 3) Put the top back on aligning the screws, when you lower it make sure the bottom of the rod engages with the hole at the bottom center of the canister, this is why you left the bottom lid open. Put the three star screws back in. 4) Turn the canister upside down, lid open, and keeping in mind this is thin plastic, gently tug upwards on the four fins that surround the bottom rubber seal. This part is held in by friction, so work your way around the four fins gently pulling until you work the ring they're connected to free. This will give you access to the inside of the canister. 5) remove the round perforated section by tugging upwards on it, set it aside with the fin part. 6) Take the canister to a laundry tub or large sink and holding it bottom up fill it with hot/warm water. Grasping the center section shake it vigorously and turn it upside down while shaking and a bunch of sh*t will come out. Repeat several times. 7) Dry thoroughly, you might use a hairdryer held to the center tube, but only if you can switch off the heat and use air only. Make sure its 200% dry, water will kill your machine 8) clean and replace the round perforated section 9) replace the fin section, I'd suggest pulling the round rubber part off of the fin part and setting it in place on the canister first, then follow with the plastic fin part. If you don't do it this way the rubber won't seat properly and the bottom lid won't close. 10) Close the lid, replace the canister, and staaaaaart suckin like it's brand new.
2helpful
3answers
Doesn't seem to have as much section as when new. Is there some routine maintenance I should be doing?
Top Pontec Garden Experts
Jay Finke
Jay Finke
john h
Are you a Pontec Garden Expert? Answer questions, earn points and help others
