Question about Epson Stylus NX400 InkJet Printer
Have changed all cartridges on epson nx400. test shows 3 ink cartridges printing, except for the black ink. have run clean head utility, ink has charged. downloaded and installed printer driver. Found an update for printer driver and ran that also. it now looks like 3 color cartridges are low on ink but all i've run are tests. Black ink appears full - but is not printing.
Posted by msfitz01 on
Anthony Muzonzini
    Scholar:
  • 160 Answers
Hi
The ink reservoir doesnt have to be completely empty to fail. Replace the cartridges. Some of the jets or all of them may be clogged especially if you have not used your printer in a while. If there are cleaning instructions in the manual clean the jets and then try to print from the printer's self test
Goodluck
Posted on Mar 10, 2011
Epson stylus nx400 no ink after changing cartridges
Inkjet printers need to be used frequently to prevent inkdrying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jun 11, 2012 | Epson Stylus NX400 InkJet Printer
How to remove epsom NX400 print head
The print head on the NX400 printer is integrated into the ink cartridge and therefore when you remove the cartridge you are removing the print head. . . If you want to clean the print heads / nozzles then see the procedure in the NX400 User Guide in the section for Adjust Print Quality. . . .The User Guide can be found at http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=106004&prodoid=63075469
Sep 19, 2011 | Epson Stylus NX400 InkJet Printer
I have an epson NX400 inkjet printer, all ink cartridges are full and are installed correctly. When trying to print, the black ink is not being printed. I have tried doing several head cleanings,...
hey friend,
This should be the problem of print head ink nozzle block.The nozzle for the black ink cartridge got dry.So the ink getsdried state.It won't allow any inks passing through the micro nozzles.Head cleaning won't help with the heavy nozzle block.So try replacing a new black cartridge or else bring the printer to the nearest service center.It'll help so.
Mar 06, 2011 | Epson Stylus NX400 InkJet Printer
I've just replaced the black ink cartridge for my Epson Stylus TX100, ink level is ok as the indicator shows. But i get blank prints for black, other colors are fine. What's wrong with the black ink...
There is nothing wrong with the black ink. Just run the head cleaning for better printing.
1. Go to printer and faxes
2. Right click your printer ( Epson Stylus Multifunction Printer/ Copier/ Scanner InkJet)
3. Click printing preferences
4. Click Maintenance Tab
5. Click Head Cleaning
6. Run head cleaning for 5 times then try printing.
Nov 15, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Hi-My Epson NX400 inkjet printer does not
Hi there
You can download this from my website.
Main features.
SSC Service Utility allow you to do many amazing things with Your Epson printer :
1) Work directly with CSIC in Epson Stylus printers cartridges.
2) Reset or rewrite any chip using special addon device.
3) Freeze internal ink counters.
4) Reset internal ink counters even with empty cartridges.
5) Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode.
6) Hot swapping of cartridges supported.
7) Resetting of protection counter (even then it is already full).
8) More then 100 different Epson printers supported
This allow many people with high printing demands to save some money (program works with both black and color cartridges).
Up to day this software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers.
Download Free
Click Link = http://www.4all2sell.com/reset-tools/sscserve.exe
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Mar 18, 2010 | Epson Stylus NX400 InkJet Printer
I have an Epson NX400 printer but the yellow and black ink test pages are showing gaps and missing lines. I replaced both ink cartidges twice and did the head cleaning and nozzle check but nothing seems to...
Try to print something that is pure yellow and pure black. Set it to BEST PHOTO. If you see gaps or missing lines, your print head could be clogged. You will need to use a cleaning solution to remove the clog.
Jan 16, 2010 | Epson Stylus NX400 InkJet Printer
My magenta ink will not print out. All other colors (including black) are printing out fine and alignment is good. I have run the nozzle check, head cleaning, status monitor, and ink cartridge replacement,...
Depending on the age of the printer and how often it is used it could be a dead piezo element in the magenta head or some dirt that is trapped in the feed mechanism to the head.That's why i never use refilled or poor quality substitute cartridges. Some Epson printers lasts for ages but unfortunately due to the head being permanent on all epson inkjets the only way out is for the replacement of the heads or a new printer. You could also try the magenta cartridge on another same model epson if you have access to one to see if the cartridge is perhaps a dud. Or alternatively purchase another cartdridge and check it out.
Aug 01, 2009 | Epson Stylus NX400 InkJet Printer
Epson NX400 works but will not print any ink on the paper
did you remember to pull the tape off the print head before you installed the new cartridge?
May 28, 2009 | Epson Stylus NX400 InkJet Printer
My Epson NX 400 is giving me this error message:Error B88/69/68 C
Try to run the ink pad reset utility software.
Please log on to epson.com. The software runs on win xp and win vista.
Mar 31, 2009 | Epson Stylus NX400 InkJet Printer
Epson Stylus NX400 InkJet Printer Logo
756 people viewed this question
Top Epson Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
