Question about Toshiba Satellite L670DST2N02 Laptop
''bad media or corrupt file''. I tried to install some game on my laptop(toshiba satellite) and i gat this message. How too fix this. Any ideas? (exp.game is '' wolfenstein enemy territory ''. help plzzz :) Iz it A hardver proplem or ...?
Posted by mmleddeni on
Anonymous
    New Friend:
  • 81 Answers
Sounds like the system files are corrupt or missing. If you still have the operating system cds, use that to use the OS system repair tool.
Posted on Mar 09, 2011
How to fix a toshiba satellite, saying no bootable checking media
Your MBR is corrupted - MRB = Master Boot Record
-Windows repair disk should fix the issue
-if not try re installing windows - but you will lose your data
Sep 02, 2014 | Toshiba Satellite Computers & Internet
When i start laptop message showing dll could not be opened
Dll errors occur due to various reasons - incomplete installation or removal of a program, missing, corrupt, or incorrect .dll file paths, and more. Failure to fix these errors can result with severe PC problems
click start right click on my computer you should see your drive usually C: select properties click tools check now tick both boxes automatically fix files and scan for and attempt recovery on any
bad sectors or you could tick one box and wait until its finished then return and tick the other box
then select check now start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
also download a registry cleaner
http://download.cnet.com/jetclean/3000-18512_4-75627788.html
JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again.
hope it helps
Sep 26, 2012 | Toshiba Satellite M40X-299, Satellite M40X...
Toshiba satellite pro l450-13q PXE-E61 media test failure check cable
This indicates hard drive issues, or windows files have been corrupted. If you have a backup disk try and load windows, no change! have the hard drive tested for possible replacement.
Jul 08, 2012 | Toshiba Satellite Computers & Internet
Im on my pc and im wondering where i can find a free download that can help me i get this message on my toshiba satellite a85s107... File missing or corrupt: \windows\system32\config\system\
Assuming you already tried pressing F8 on boot up and trying to get it into safe mode to run a disc check and that did not work?
This is a configuration file that can only be repaired by the use of OS installation CD, which if the laptop is booted with the disc in the drive and the bios is sett o boot from the DVD drive first, will give you the option to carry out a repair of the installation
Jun 21, 2012 | Toshiba Satellite A85-S107 PC Notebook
Toshiba satelite l655 wont boot windows or safe mode
The hard drive has failed, or windows has corrupted files. If you made a backup cd installation disc that would be the next step to try and load windows, if no change! the hardware needs to be tested for possible replacement.
Apr 19, 2012 | Toshiba Satellite NoteBook Intel Pentium...
Have tried to completely restore laptop by running dvd recovery disks. Inserted disk 1 ,after a while got message "bootmgr missing" Any ideas?
There are corrupted files from the recovery disc which the computer cannot read. Use another recovery disc.
Hope this helps.
Jun 12, 2011 | Toshiba Satellite Pro L300 Notebook
My Toshiba Satellite keeps freezing. The laptop is a a205 5800 series laptop
Your operating system is corrupted, this can happen due to many reasons (ex:- bad installation). you need a repair operating system
Dec 16, 2010 | Toshiba Satellite A205-S5804 PC Notebook
Corrupt registry
When the Windows registry is corrupt, there is no other solution except to re-install Windows. There is no tool that can truly fix a corrupt registry.
Oct 29, 2009 | Toshiba Satellite M45-S165 Notebook
My sound device isn't working anymore?
Try to reinstall the sound driver cd of your laptop.
Apr 20, 2008 | Toshiba Satellite M55-S325 Notebook
Failed Web Camera Installtion
Reinstall the driver, or uninstall the driver and do a fresh install with the correct drivers, check if the usb2.0 drivers are installed.
Jan 08, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite L670DST2N02 Laptop Logo
Top Toshiba Computers & Internet Experts
k24674
Michael Thomas
Michael Thomas
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
