Canon MX700 Office All-In-One InkJet Printer Logo
Posted on Mar 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Yellow light keeps flashing underneath triangle- Error code 6480. Please advise what this means? many thanks
MJ'S Computers .Unlt
Level 2:
Habit-Forming:
  • Expert 85 Answers
  • Posted on Mar 09, 2011
Expert
Level 2:
Habit-Forming:
Answers
85
Questions
0
Helped
21402
Points
235
There is a thin (1/4"wide) plastic strip running across the width in front of and below the drive belt. This is part of the optical encoder that tells the print-head where it is. If you look closely, there are fine black vertical lines on this strip. If the strip gets a piece of crud on it, you get an error during the start-up sequence. Gently clean this strip with a damp lint-free tissue. This also will fix a gap in the printing running lengthwise (not across the page like a clogged head).
I have a triangle error symbol in the lower right hand side of my printer, it has a lightning bolt inside of the symbol........what does this mean?
Canon printer light blinking error is a common error. Each printer features a flashing light to indicate its functionality. With Canon printers, you have flashing green and orange lights to inform you of any existing problems. It is suggested to carefully observe the number of flashes or the pattern of blinking lights as this will help you to understand the problem. And depending on the pattern, you can follow our canon printer troubleshooting guide mentioned below to solve that issue.
What does triangle with lightning bolt mean on Canon printer?
The orange triangle with the lightning bolt comes on when the printer is plugged in. The white light above the power button is on, but the printer is otherwise dead.
What does the orange triangle mean on my Canon printer?
When a printer error occurs, the Alarm lamp flashes orange as shown below. The number of flashes indicates the type of error that has occurred. Count the flashes and take the appropriate action to correct the error. Power Lamp Flashes Green.
What does the triangle symbol mean on my canon printer?
Seeing a yellow triangle with an exclamation mark usually indicates that a hardware device needs to be updated. If you are seeing the mark in Device Manager, we recommend checking the device status of the printer driver.
What does the flashing yellow light mean on Canon printer?
When an error occurs in printing such as the machine is out of paper or paper is jammed, a troubleshooting message is displayed automatically. Take the appropriate action described in the message. When an error occurs, the Alarm lamp flashes orange and a Support Code (error number) is displayed on the computer screen.
How to get rid of the yellow triangle
The yellow triangle means there is an https error. (https:// means the website is secure, while http:// denotes the connection is not secure). If you right click on the triangle it will give you a breakdown of what is causing the error.
1helpful
Check engine light flashing
When the check engine light is flashing it means that the computer has detected a misfire in the engine.It is not good to drive a vehicle that has a flashing check engine light; one or more sensor in your vehicle is advise about an code fault. I suggest scanning for know what code is in there and solve it.
In some vehicles, a red check-engine light means the car needs absolute immediate attention while a yellow check-engine light means you need to make an appointment soon. The light is used to indicate PCM (Powertrain Control Module) problems that are associated with your vehicle's emissions system.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Check engine light reset
2helpful
Check engine light jeep grand cherokee 2001
When the Check Engine Light is flashing ON it means that the computer has detected a misfire in the engine.It is not good to drive a vehicle that has a flashing check engine light; one or more sensor in your vehicle is advise about an code fault. I suggest scanning for know what code is in there and solve it.
Check Engine Light comes off and on
3helpful
2answers
What does it mean when the battery icon light it flashing yellow?
If the battery indicator is flashing despite it is being charged, then the battery has internal problem which means, it's need replacement. Please check that the battery is not physically damaged and check the voltage. Keep it outside without charging or installing on the system for few hours and try again. If this doesn't help, you'll need to replace it. Good luck. Thanks for using FixYa.
1helpful
2answers
Light with the triangle flashing - printer stopped
That means ATTENTION, you are either out of toner or have a paper jam.
Flashing error message C:31:23
Hi Jazzy,
Please see the detail below for the said error codes C31:23.
According to the symptom and self diagnostic system the problem is in mechanical section (tape loading section) Therefore camera just need mechanical adjustment and will work fine again. This problem aries when the insertion of the cassette is improper or forced insertion.
Thanks for using fixya.
1helpful
Warning symbol on mini cooper
If it is yellow and looks like a tire it is the flat tire light, and you should check his tire pressure. if it is a yellow triangle with an arrow going around the triangle with a exclamation point in the middle this is your DSC or ASC and if it is on all the time these features are inactive and you should hit the DSC/ASC toggle switch to the right of the drivers window switch. If this symbol just flashes briefly this means the DSC/ASC is presently activating. thest are the tow that I can think of, I hope this helps.
old marine
old marine
ZJ Limited
ZJ Limited
