Rule 1800 H53SP-24 Swimming Pool Cover Pump Logo
Posted on Mar 09, 2011
H53SP-24 pool cover water pump: Pump quit; circuit ok; occasionally when plugged in gives a 1 second whirl, then stops; after a few minutes it does the same thing if plugged in again; if I plug in right away after unplugging when it quits, it doesn't do anything- you have to wait a few minutes to get a new burst, then it quits again after just a second whirl of the motor.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 21, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1296
Points
5
I have the same issue. I pulled the pump from the assembly and bypassed the circuit board inside by creating a circuit with the 2 black wires...pump worked fine. Of course, it won't cycle on and off so my guess is that the pressure switch somewhere in the circuit board is bad. Rule has a great warranty as my current unit is a warranty replacement (2 years ago). Last unit had a stamped date code on it. I contacted tech support ( [email protected] ) and got a new one sent out. The replacement did not have a stamped date code, so my fear is that they won't replace this one. I picked one up online for $99 and free shipping. If I get resolution on the broken on, I will have on as a backup.
Good luck and if yours is less than 3yrs old, contact tech support.
  • Anonymous Oct 23, 2012
    How did you bust the case open to get to the circuit board? I cannot figure out how. thanks
  • jeffrey
    jeffrey Jun 13, 2020
    if you pull on the impeller, the motor should slide out enough to unhook the connectors
Take apart rule pool cover pump
motor seized how over the winter the discharge hoses freezes thus no discharge pump burns out motor that is
Plug the pump in and it runs for a few seconds and cuts off and repeatsand it is not in water
water has to be high enough its going through a self test if the blue leaf guard is not undr atlest 3inches of water that's what will happen
Water is draining from pool iwth Rike 1800 pool pump, but flow is very slow and weak and definetly nothing like 1800 GOH
How long is the hose the pump is connected to?
What is the inside diameter?
With no hose, the pump gives 1800 gph, 30 gpm
with lots of small hose, that could drop to 5 gpm.
Ensure no debris in inlet or hose.
Gary
2helpful
I have a Rule 1800 H53SP-24 Swimming Pool Cover Pump. Everytime I plug it in it trips the breaker. Did not have this problem with the same pump a month ago. Tried in GFI and all other outlets. Any...
Hello. There are several possible issues here which are all fairly easy to investigate. Begin by bringing your pump, cord and hose into a warm space for 24 hours to thaw everything out, warm it up and dry it out. Then try it. If it works, you know you have one of the problems described below:
1. Sometimes a circuit breaker wears out and needs to be replaced. Try your pump on a different circuit, insuring that you are using a different circuit breaker. IF it works there, the solution is to replace that worn circuit breaker. 2. Check the impeller and remove any clog, blockage, debris or residue. 3. The 24 foot cord on your pump might have a cut, or a scrape on it. If it does, water is getting into the insulation and causing the circuit breaker to kick. Check your cord thoroughly and if you do have a break in it replace the cord or repair it with a waterproof repair. 4. Your pump motor may be worn or faulty or have a water intrusion. In that case the only fix is to replace the pump. 5. The drain hose could be frozen. If it is, that blockage could cause the breaker to kick. Always ensure that the hose runs consistently downhill.
If you would like to contact Rule, you may do so at the following link: http://www.rule-industries.com/
Regards, Joe. Please rate my answer. Thank you and happy holidays.
Rule H53sp-24 pool cover pump trips GFI breaker
GFI devices are prone to degrade over time. Also, when used outdoors there are additional moisture issues that may cause sufficient current leakage to trip the breaker.
I had a similar problem this Spring. I was using a 20 amp GFI "master" outlet that protected two additional outlets 'downstream' of it (wired to the 'load' terminals on the GFI outlet- I'd have the check the doc. to see what terminology was used here). The pump was plugged into one of the downstream outlets.
Replacing the GFI seemed to solve the problem. I did ante up $20 for an 'outdoor' model of the 20 amp GFI unit, several bucks more than the standard 'indoor' unit - have no ideal if that represented additional value or not.
Note also, that this is the third such pump I have used for my pool cover. The other two failed to come on at all after about a year's use. The mfg replaced them under warranty (I may have had to send back the old pump - I forget!).
Curtis
Rule 1800 gph pool cover pump will not run
The sensor that checks for h20 every 10 seconds may not be working properly. First make sure the pump is unplugged then clean the pump making sure the impeller is free never do this with it plugged in. tap the pump lightly with a screw driver handle to make sure the bearings are not frozen if it still does not work send it back to the manufacturer
1helpful
I have a rule 1800 computerized pool cover pump. As soon as I plug it in, it runs a few seconds then shuts right off, WON"T keep running. (this is outside of the water, dry) any help?
That's a good thing. That pump uses resistance on the impeller to alert it to the presence of water. It will periodically start and run for a few seconds. If there is any water present, it will keep running, otherwise it will shut off until the next time it tries. Put it in water, and see if it works there.
Top Rule Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Rule Pool and Spa Expert? Answer questions, earn points and help others
