The question about how to
reset Windows Vista password is often seen on various forums and Q&A websites. It is a serious problem for you if you are not good at PC. But if you are familiar with computer, the answer to the question can be very simple. There are many fast and easy ways for you to reset the password. Here it introduce you a simple one - create a Windows Vista password reset disk and use it to help you perform
Windows Vista password reset.
Method 1: Reset Windows Vista password through Vista operating systemWindows Vista allows you to create a password reset disk with a USB flash drive in a few seconds. It can help you reset Windows Vista password when you forget it.
Part 1: Create Windows Vista password reset disk
Step 1: Log on your Windows Vista computer.
Step 2: Insert a USB flash drive in computer.
Step 3: Click Start button to select Control Panel.
Step 4: Click User Accounts and Family Safety in the following screen.
Step 5: Click User Accounts when a new screen appears.
Step 6: Click Create a password reset disk in the left pane in the coming up screen.
Step 7: The Forgotten Password Wizard will open, and then click next.
Step 8: Select the portable media drive which you want to create a password reset disk on, and then click next.
Step 9: Enter your current password, and then click next.
Step 10: Click next when the progress indicator shows 100% complete.
Step 11: Click Finish in the next window.
Step 12: You can now remove the flash drive from your computer.
Now you have successfully created a Windows Vista password reset disk. And you'll find a Userkey.PSW file when you open USB flash drive. Keep the file or USB flash drive in a safe place. You'd better to mark the USB flash drive so that you can distinguish it from other USB drives. When you forget password on Windows Vista and cannot log on your PC, you can use the USB password reset disk to reset Windows Vista password. You could follow the below steps.
Part 2: Reset Windows Vista password
Step 1: Start your computer and get to the Windows Vista logon screen.
Step 2: Type a wrong password, and then press Enter.
Step 3: Click OK when the error message that the user name or password is incorrect. And the Reset password link will appear on the Vista logon screen.
Step 4: Click Reset password to open Password Reset Wizard screen.
Step 5: Insert your USB password reset disk in computer.
Step 6: Click Next on the Password Reset Wizard screen.
Step 7: Select your USB password reset disk, click Next.
Step 8: Type and confirm a new Vista password.
Step 9: Input password hint, click Next.
Step 10: Click Finish when you've successfully reset Windows Vista password. You'll return to Windows Vista Logon screen.
Step 11: Enter your new Windows Vista password to log on your Vista machine.
Please Note: You must create the Windows Vista password reset disk before losing your password.
Method 2: Reset Windows Vista password with Windows Login RecoveryIf you are locked out of Vista PC without a Windows Vista password reset disk, you'll need Windows Login Recovery to create one. This Windows password recovery software allows you to use a USB flash drive or blank CD/DVD to create a bootable Windows password reset disk. With it, you'll never to be worried when you need to perform Windows Vista password reset. It is also easy for you. Follow the below steps.
Step 1: Download Windows Login Recovery and install it on a computer that you could log on.
Step 2: Burn a bootable CD/DVD or USB flash drive password reset disk.
Step 3: Reset Windows Vista password to be empty.
Step 4: Log on Windows Vista without password.
