Computers & Internet Logo
Posted on Mar 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fix stuttering and pulsing fans - Computers & Internet
Anonymous
Level 2:
Sergeant:
  • Expert 212 Answers
  • Posted on Mar 09, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
212
Questions
0
Helped
55824
Points
632
First I would see if they are overly dusty. If you open the case and blow the dust out with compressed air, this can help.....fans can sputter quite a lot if they have an excess of dust which happens all the time.
If getting rid of the dust does not help, it is likely to be either a power issue, or a controller issue.
so....next, try re-seating the power cables that come off of the sputtering fans, and make sure they are plugged into the right spot on your motherboard (your motherboard manual should have this diagrammed) and make sure they are fit snugly to the connector. The fan could also draw more power than your power supply can handle, therefore you could be in line for a new power supply.....if the fan worked well previously and just started this sputtering it could be due to a new piece of hardware (have you upgraded anything?) that could be drawing more power from the power supply.
If neither of these is the case, many motherboards and chipsets have built in fan controllers...Basically they are supposed to automatically adjust the speed of the fan based on how hot it gets inside the case. This keeps the fan on lower power (and thus quieter) until it gets to a point where it has to run higher because of more heat. These controllers can sometimes go a little haywire, or the heat sensors can fail.....you may be able to enter your system's BIOS and manually change the fan settings to prevent the sputtering.
If it is not dust or power, you may have an issue on your motherboard which is a larger problem, that you may want to have a local tech look at. (if you feel the PC is worth fixing for what they will charge you)
Raj Patel
Level 3:
Genius:
  • Master 1,042 Answers
Raj Patel
Master
Level 3:
Genius:
Answers
1042
Questions
Helped
270230
Points
3723
Clean them or replace them.
I have a a Luxair kitchen extractor fan which is pulsing and lights are stuck on
If this is a "Timed run-on" fan then the fault is almost certainly on the small Printed Circuit Board that controls the Fan.
There are two Electrolytic Capacitors on the Board: A 47uF@16V near the timer Control Pot which fails giving a symptom of pulsing or hunting. The second is a 350uF@16V which is near the 14 Pin DIL Chip and controls the run-on timer duration. Both components are easily replaced and this will restore the fan to full function.
Oct 05, 2016 • Dryers
2000 ford f150 Manuel trans. Code p0320 is it a expensive repair? Stutters while in gear 3/4 but doesn't stall. Just started a few days ago
P0320 means that an ignition pulse that's supposed to fire a spark plug was missed. It could be as simple as a chafed wire under the hood. Watch this video:
Ford has some information too:
P0320 2000 Ford F150 Ignition Distributor Engine Speed Input Circuit...
Faulty Injector Pulse
THe pulse is generated by the crank shaft sensor, then it goes to the ECM, then to the injectors.
4helpful
I have a coleman powermate pulse 1800ex generator. It stutters when put in the run position. when in the choke position it doesnt stutter.
your main jet is plugged shut off fuel, remove bowl from carb(bottom of bowl) clean out small holes on screw with stranded wire .2 holes on side on in middle. be sure to put fiber washer back between main jet and bowl and use fresh gas jor
1helpful
Brake peddle pulsing and radiator fan not coming on
Brake pedal pulsing is either ABS working or discs with excess "runout"
Radiator fan not working, check fuses, connections to fan, ?faulty thermo fan switch, faulty fan motor.
NonStop Graphic Problems on 5870
Update your drivers to 10.2, see if that fixes the problem. http://game.amd.com/us-en/drivers_catalyst.aspx If it doesn't get back to me
I have a vokera unica 28 which pulses when firing
your fan may need attension fan runs after boiler shuts down is normal on some Vokera,s too clear fumes out the flue 2mins approx
5helpful
2001 BMW 330ci Blower Fan quit working
sounds like the resister for the fan is failing. it is located under the dash on the duct work for the blower (fan). you will see two wires going to it. unscrew the bolts or screws that hold it in and replace it with a new one. it should work fine after that.
4helpful
3answers
Tomtom stuttering
TomTom Home now has a fix which corrects the stuttering problems with the computer voice needed for the 'text to speech' function on the GO720. Simply plug your device into your computer and have it connect with your computer. You should automatically see a large fix available which will correct the problem. Download it as I did, and the problem is corrected.
Grand Canyon Tech
Grand Canyon Tech
