ViewSonic VG900 19" Flat Panel LCD Monitor Logo
Question about ViewSonic VG900 19" Flat Panel LCD Monitor
Screen flickering and streaking
Posted by helenfalk on
Anonymous
    New Friend:
  • 34 Answers
Try to change data vga cable.....
Posted on Mar 09, 2011
Anonymous
    New Friend:
  • 10 Answers
Is it a new computer you have? or a new installation of windows? you may need to install the current VGA driver for you pc.... but try this first
THE FOLLOWING IS STEPS ON XP. OTHER VERSIONS OF WINDOWS MAY VARY
right click on your desktop - go to properties
click on the "settings" tab and then go to Advanced
Click the "monitor" tab and you can change the refresh rate in there - up the refresh rate if it will alow you, failing that, rather than the "monitor" tab , have a look if there is a tab that relates to your VGA driver (usally on the back row, its a long tab called Intel graphics, or ATA graphics or something like that)
that usually has an option for refresh rate. if there is no option to change refresh, i.e. the only rate you can choose if 60 Hrz for example, then your best bet is to download the graphics driver from the vendors website
Screen flickers and pictures have lines across them on my lumix DMC-TZ3
The camera is probably damaged, this also happend to my DMC-TZ5 as well after a few (5-6) years of heavy use but without any visible damage, a repair is most likely more expensive than just buying one of the new lumix cameras which have also improved A LOT, so you wont be disappointed!
Streaks across the pictures and some flickering on screen
Hi
the LCD screen may be faulty, or the connecting strip loose or corrosion on it, clean, if necessary change.
How to factory reset with only remote, while screen remains black w/ 5 thin horizontal colored lines streaking. Why is screen black?
Without a proper screen, you can't do a factory reset to this set. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
I have a LG 42LB5D 42" 1080 LCD television that
hi, usually you can correct this issue with only a few system checks, dark streaks can be caused by damaged pixels on the screen, in which case you need to replace the TV.
  • Inspect where the dark streaks are on the television. If the streaks occur at the same place on the top and bottom of the screen, they are due to the formatting of a movie or television show you are watching. This is normal. Also, if the streaks appear on the left and right of the screen, they are due to the show being filmed in full-screen instead of wide-screen. This also is normal.
  • Change the input setting so you are viewing the contents of a different device. If the dark streaks are gone, you know they are due to the device connected to it. However, if the dark streaks remains no matter what input the TV is connected to, the problem lies with the television.
  • Inspect the cable connection. Oftentimes when connecting a computer to an LCD TV, you can have strange dark streaks across the screen. Use a DVI-to-HDMI cable connection when plugging in your computer, then press the "Menu" button on your TV remote, select "Picture" and chose "Square Pixel." See whether the image adjusts and the dark streak goes away.
  • Contact the manufacturer of your LCD television if the dark streak remains. This streak can be caused by a defect in the television; if the TV is still under warranty, you can have it replaced.
  • 0helpful
    1helpful
    Green streak on monitor
    Sounds like you may have a power source or speaker with a magnet to close to your monitor. Either that or it is getting ready to die on you.
    Right side of screen flickering (top to bottom)
    Your laptop screen has a thin ribbon connecting the screen to the mainboard. after upening and closing your screem these pins sometimes breaks causeings streaks in your screen. My compaq note book has to be resoldered because of a lose connection on back for power. your gonna want to get that fixed before you fry your board. costs about 50 bucks for an hours work to get that solderd. It could be linked to your flikering issue..
    Red streaks
    http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
    2answers
    Hitachi rear proj TV, light blue vertical streak center screen, moves slowly
    Sounds like a source problem. What happens when you play
    a DVD or some other source??
    Need more info? Always give Model # and age----T.
    Top ViewSonic Computers & Internet Experts
    Steve Nordquist
    Steve Nordquist
    Steve
    Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
