If you have an HD receiver you will want to use one of two types of
cables; you can use component cables which have five ends red, blue,
green, red and white, or you can use an HDMI cable which will have one
flat connection. If you have a standard definition receiver you will
want to use RCA cables these have three ends red yellow white. The
connections will be labeled on the television as well as the receiver.
Once you get this connected hit the input/source button on your TV set
if you're using RCA cables you want the TV set to video 1 or video 2. If you're using an HDMI cable then set the TV to HDMI 1or 2 using the input /source button. If you use Component cables set the TV to Y/PB/PR or component 1/2.
Daniel Busa
DISH Network Customer Service
