I cant seem to get an access point anywhere in my house to connect my psp to, i can see my personal connectiong abut whenever i try to connect to it it fails and repors back saying my access point was lost. helpp!
Posted by nigelnyangan on
Louie Laforteza
  • 135 Answers
Try to change the wireless LAN channel of your router. Normally it is set to automatic. Change it to Channel 2 or 5.
Posted on Mar 09, 2011
My PSP internet connection not supported to my access point.
The SSID is the NAME of your Routers connection. So you need to know your WiFi connections Name, That's the "Access point" Security, Is IF you assigned a WEP/WAP KEY, when the router was first setup. If NO Key is set, that is what it means "Unsecured",
You need to get a Netgear router manual, for your exact model, it shows all in pictures how to do it.
Apr 25, 2010 | Sony PlayStation Portable (PSP) Slim...
Weres the aoss button
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I think there is no AOSS button on your PSP. AOSS is a wireless solution made by www.buffalotech.com. Most new wireless routers/access points has this capability. AOSS is on the wireless router/access point and not on the PSP.
AOSS will automagically determines and configures the connection of a PSP to a wireless access point by pressing the AOSS button on the wireless access point.
Apr 09, 2009 | Sony PlayStation Portable (PSP) Slim...
Dns eror
you must know the dns address of your access point or wireless router you must creat new connection to psp scan and manual edit the primary dns and the dns address of your access point or your wireless router
Nov 13, 2008 | Sony Limited Edition PSP Daxter...
Psp
The following items are generally required to set up to connect to a network.
  • A WLAN access point or a wireless broadband router
  • Settings for the access point (SSID, WEP key, WPA key, etc. as specified when the access point was configured)
  • A network device, such as an ADSL/DSL modem or a cable modem.
  • An account with an Internet service provider
Hints
  • An access point is a device used to connect wirelessly to a network.
  • A router is necessary if a PC and the PSP™ system will be connected to the Internet at the same time. A router is a device that enables multiple devices to be connected to one Internet line.
  • SSID, WEP and WPA keys are types of wireless network information. This information may be required when connecting to an access point or a router.
  • User is responsible for Internet service fees.
Example of a network configuration Network equipment connection and setup methods vary depending on the equipment used.
require001.gif Common settings hr1.gif You can create network settings for use in connecting to the Internet through an access point and save them on the PSP™ system. You can save up to 10 connections.
Setting methods may vary depending on usage conditions. The following is an example of commonly used settings.
1.
Check that the settings for the access point have been completed.
Check that there is an access point connected to a network with Internet service near the PSP™ system. Settings for the access point are typically set using a PC. For details, contact the person who set up or maintains the access point.
2.
Select in_networkset.gif (Network Settings) under in_setting.gif (Settings).
3.
Select [Infrastructure Mode].
4.
Select [New Connection].
5.
Select [Scan].
The system searches for nearby access points.
Depending on the model of PSP™ system in use, you may have the option [Automatic]. Select [Automatic] when using an access point that supports automatic setup. If you follow the on-screen instructions, the necessary settings will be completed automatically. For information on access points that support automatic setup, contact your local retailer.
standard001.jpg 6.
Select the access point that you want to use.
SSID is an identifier assigned to an access point. If you do not know the SSID or the SSID is not displayed, contact the person who set up or maintains the access point.
standard002.jpg 7.
Select the type of security that you will use.
The type of security settings required vary depending on the access point. For details on what type to use, contact the person who set up or maintains the access point.
standard003.jpg 8.
Enter the encryption key for the security settings.
The encryption key field displays eight asterisks no matter how many characters you enter as the key. For information on the encryption key, contact the person who set up or maintains the access point.
standard004.jpg 9.
Select [Easy].
Basic settings are set automatically.
standard005.jpg 10.
Enter a name for the connection.
You can choose any name for the connection.
11.
Check the list of settings.
standard006.jpg 12.
Save the settings.
13.
Test the connection.
If you select [Test Connection], the system will connect to the selected access point.
14.
Confirm the connection test results.
If the connection is successful, information about the network connection is displayed.
Hints
  • If the connection test fails, follow the on-screen instructions to check the settings. Network settings for the connection can be changed from the options menu. For additional information, refer to the instructions supplied with the network device and by your Internet service provider.
  • Depending on the access point settings, you may need to enter the system's MAC address to connect to the network. The system's MAC address can be checked under in_setting.gif (Settings) > in_pspset.gif (System Settings) > [System Information].
Jul 12, 2008 | Sony PlayStation Portable (PSP) Console
How do i get wireless internet on my psp?
If there is a wireless connection anywhere near range of the PSP that is NOT secure, you should be able to access the wifi option in your menu section of the game system.
Mar 16, 2008 | Computers & Internet
Problems with my connection
your PSPs are attempting to connect to the net, via a wireless connection device. they are timing out for several reasons.
1:- cannot locate or connect to server.
2:- cannot connect or failed to connect to router or modem.
3:- your PSP is firmware version 1.50 ( this does not support a web Browser )
4:- the firewall if applicable, needs to allow the psp access as a trusted device on the network.
These are a few reasons, why your psp will not connect.
There are others, but these are quite significant.
hope this helps any of you.
Mike @ Compurepair.
information supplied by, 13 year old son ( PSP Addict AKA Rabbit )
Feb 21, 2008 | Sony PlayStation Portable (PSP) Console
Psp no connection to internet
Why can't I connect to the internet on my psp I tried over & over nothing it says the connection to the acces point has timed out..
i still can't connect even with wireless router
Jan 27, 2008 | Sony PlayStation Portable (PSP) Console
Problem with browser on my psp
I don't think the problem is with your PSP. It may be you router (Internet connction). Have you tried unplugging your router and plugging it back in after a minute? That usually does the trick for me when my PSP is having trouble getting on the net.
Dec 04, 2007 | Sony PlayStation Portable (PSP) Console
WIFI does not work: internal error 00000001
dont worry its no problen sony did not encode the higher versions it should say no network found but but it is the same thing so dont worry
Oct 05, 2007 | Sony PlayStation Portable (PSP) Console
Computers & Internet Logo
102 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
