Question about AOpen DUW1608/ARR (914ID37002) DVD±RW Dual Layer Burner
My DVD Burner will not open but it shows a red light which leads me to believe that it works but there is a problem with how it is connect or maybe it is an internal problem.
Posted by archabla on
Anonymous
    Problem Solver:
  • 6 Answers
Hi there, you should probably try to open the burner manually, to do so, usualy there is a small hole on the from that you should push with a pin and this will open the dvd. Sometimes the dvd can get stuck if it is not centered perfectly. Thanks.
Posted on Mar 09, 2011
My vista laptop will not show my xternal dvd 1633s drive when plugged in
make sure all connecting leads are good with secure dust free connections
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jul 10, 2012 | Lite On SOHW - 1633S DVD±RW Dual...
The burner will work with no problems on a slow port but when connected to a hi-speed port the message that it is a unknown device pops up. I keep re-booting the computer till it finally works right but...
first up
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jan 09, 2011 | HP dvd1170e DVD-RAM Burner
Drawer opens halfway and has to be pulled open far enough to insert disk. Sometimes opens all the way --- baffling.
hope this helps
Dec 31, 2010 | Samsung SHS222L DVD+R Burner
When i put cds in it works when i put a dvd in i go to computer the drive shows nothing but when i put a blank dvd in it shows it but cant burn nothing to it
hope this helps
Dec 27, 2010 | Lite On LH-18A1P DVD RW Dual Layer Burner
Drive lights up but is not showing up on the computer
hope this helps
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Dec 18, 2010 | BenQ DW1640 DVD RW Dual Layer Burner
When i try to copy files in writable disk folder it shows problem copying. . .when try to write disk using nero it shows burning failed.please help
hope this helps
Nov 30, 2010 | LG GH24LS50 Super Multi DVD±RW (±R DL) ...
The CD/DVD Rom will not open, nor do any lights flash as if it were working. The CD/DVD Rom doesn't appear in the Device Manager either. What do I do?
test the leads that are attached to your cd/dvd make sure they have a secure connection or replace them maybe old and faulty
hope this helps
Sep 06, 2010 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
My dvd drive detect but do not open tray and led is not blinking
There are 2 leads to connect to the dvd drive. One is the ribbon cable that allows the data to pass between the dvd drive and the pc. The other is a power lead. Either the power lead is not connected or is not pushed fully home.
Jul 26, 2010 | LG GSA-H55N DVD-RAM Burner
Problem with yamaha crw8424s...this device was working untill today...now the device has 2 flashing red lights, is no longer recognized, and drawer does not open or close. Any ideas or is this device shot...
Power off the PC, open the case, disconnect burner, power on pc, restart it, power off, reconnect burner, power on. If it work's then you're done. If no, ask your local computer story for a DVD burner
Nov 20, 2009 | Yamaha CRW 8424 Burner
HL-DT-ST DVD-RAM GSA-H54N 18 X DVD BURNER
open the cabinet  try changing the cables connected to it   and restart  the system this will do
if not then reinstalll l the os after makin essential backups
Jan 01, 2008 | LG GMA-4020B Super-Multi...
Computers & Internet Logo
Top AOpen Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
