Question about Kenwood 107VR
My kenwood kr v1074 reciever doesnt seem to do the job of my other reciever.....my sub is connected threw the red and black ports tried em all and my speaker just remains low volume even if i have it full power on the back,,,,,,,, mabe i dont have it hooked up right? can somone help please
Posted by lilvicc2 on
David Dunn
    Brigadier General:
  • 8,546 Answers
You shouldn't hook things up and guess how they work.
BTW "KRV1074" doesn't bring up a valid link anywhere in the universe except your request.
Try finding the manual here...
http://www.kenwoodusa.com/ Use the Search box.
Posted on Mar 09, 2011
Avr kenwood kr v5090
Have you tried the "Simulated" surround setting?
If you don't get sound in "Simulated" mode then you have probably lost the surround channels.
If you do get sound then your "Media"
is not recorded with a surround "Track". or the surround "Processor" may have issues that need to go to the repair shop.
Mar 25, 2014 | Audio Players & Recorders
Kenwood SW-32HT Subwoofer Dropping sound Yamaha Reciever
Several possible answers. First - is that the Yamaha has a fault that is sending a signal with too much power on it. And the sub detects this and switches off.
Second - either the Receiver or Sub is switching off when no audio is present. A setting problem?
Third - the sub has a fault, possible overload, and goes to standby for safety.
Jul 01, 2017 | Audio Players & Recorders
Can the Kenwood KR-4600 connect to an ipod?
Hi,yes you can connect Kenwood KR-4600 to an ipod.
Instruction..
You will need an coolken_9.jpgRCA cable .
Connect the RCA (red and black to the input of the Kenwood KR-4600...You have options of inputs to use..
Either input at the back of the Kenwood KR-4600,or tape A and tape B..which ever you wan to use..
After connecting the red and black RCA to Kenwood KR-4600, then connect the other jack end to the ipod, and go the front of the Kenwood KR-4600 to activate the input selection knob to the desired input being selected at the back of the Kenwood KR-4600..
And don't forget to turn on the volume of the Kenwood KR-4600 and also the iPod volume..
And after that your done..
Good luck to you..
Aug 10, 2011 | Kenwood Audio Players & Recorders
Hi, My friend (who has a visual impairment) moved house recently, they own a Kenwood KR - V5570, I assisted with re setting up PC etc. I am now baffled with connecting her left and right speakers to this...
If you keep guessing you may succeed in blowing something up.
The cables have RCA connectors or bare wires for a reason.
Get the manual out and read it.
Register and download it for free at retrevo.com
http://www.retrevo.com/support/Kenwood-KR-V5570-Receivers-manual/id/479bh938/t/2/
Don't pay too much attention to the actual colors of speaker wire. Use the colors as reference. Each speaker has a plus and a minus. Connect them to corresponding plus and minus for their respective amplifier outputs.
Jul 04, 2011 | Kenwood KR-V5580
Where on the Kenwood KR-V5580 do I connect a sub woofer
Wherever the unidentified subwoofer's manual recommends. As there are no volume-controlled pre-amp outputs it would have to be a model that accepts full-range speaker level input if you want to control its volume locally.
Jul 02, 2011 | Kenwood KR-V5580
I have a vr 309 kenwood reciever with a bad subwoofer port because sub doesnt produce sound through it but does through another reciever, is there a fuse or capacitor just for this output i can check or...
Are you sure the VR309 is sending a signal out through the sub port? Attach one of your other speakers to it as a test (low volume). Then get back to us.
There are such things as user settings that affect this.
Dec 05, 2009 | Kenwood VR-309
Kenwood 107VR Logo
73 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
