Sounds like you have LED backlights that are going bad and the strips need replacing, its not a real easy job but if you watch some youtube vids they show how to do it.
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Sorry for the late reply, I'm offline upon purchasing my service.
I have some question so that I can give you an accurate solution regarding on your problem. 1. Exact model no. of your unit - this is located on the back cover, manual, or on the receipt. 2. Does the unit has sound, before it goes blank? 3. Does the unit goes black or white screen? 4. Does the symptoms remain the same in all inputs(when watching TV, DVD, game console, etc)?
No,
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc. http://en.wikipedia.org/wiki/Capacitor_plague Please post back what you find.
It really doesn't have a reset for the picture. I would be looking at the inverter and power supply. If it is four years old most likely it is the inverter. The inverter is on the left side looking at it from the back. Have a repair shop check it out for you. Thanks
Sounds like you dlp lamp is going out. That's a pretty old TV and if you are still running on the stock lamp this is exactly the type of thing that will happen. The lamp model for this particular tv is the ty-la1001. You can find that over here:
well if you get a screen that shows the polaroid logo with a bright ble screen then goes to black...some q's to answer for me ....does the power indicator on the lower right front of the tv go red,stays blue,or goes out completly??
There are many things that can cause this. Depending upon the type of projection set you have, the particular solution will be different. Can you please update this posting with the make and model please?
