Microwave Ovens Logo
Posted on Mar 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What am I doing wrong. Cusinart 1200 less than a year old. Takes an hour to brew. Took out permanent filter and use paper #4 filter. Has been slow since I bought it. Please advise. Other than that, great coffee.
Anonymous
Level 2:
Sergeant:
  • Expert 205 Answers
  • Posted on Mar 09, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
205
Questions
0
Helped
82798
Points
630
Try cleaning it with vinegar. Sounds like you need alot of help on this one run a full pot of vinegar through the machine. with a paper filter in the basket. then run two to three full pots of just water. this should help decale the coffee pot.
3answers
My gammon joint is 1.194 kg in weight how long do I cook in the oven for
Based on a 1200 watt microwave. Increase time for less wattage devices.
Place in a large casserole dish with lid and cover with water.
Heat on High (full power) for 15 minutes then 15 to 20 minutes per 450g at Medium power.
Allow to stand before serving as always.
1helpful
We have a 12 cup Mr. Coffee about a year old. We put 4 scoops of coffee in and the appropriate amount of water. Every day, the filter overflows and grains of coffee get into the pot. How do we keep this...
Because I own a espresso company,I believe I can help you. There is several things that can cause a coffee machine to over flow. 1, putting to much coffee in, where water can not drain through filter. 2. The grind of the coffee, if it is ground to fine, like ground for espresso, will not allow coffee to flow through filter , drip machine that are not under high pressure like espresso machines have to have ground more course. 3, wrong type of filters, not fine enough for water to flow, or made for high pump pressure machine such as espresso machine . 4, putting to much water in, is not an issue on a mr coffee, because even if you fill it to full cup line, it would have nothing to do with filter over flowing, besides the coffee grounds always absorb some of the water anyway. In conclusion, my positive professional diagnose is Grounds of coffee to course, and 4 scoops seem a bit to much for a filter of a mr coffee machine that holds only 12 cups. To test this is make a pot same way and use only two rounded scoops and see what happens, if does not over flow that solves that. But your saying I want it stronger, believe me I know. I too like my coffee strong and a flavorful . I have that solved too. Go to a good walk in espresso shop, like a star bucks, tell them you want some good strong blend and have it ( Ground for Drip) and then still only put two rounded scoops, it takes less do to the blend and kind of coffee. Please let me know if my advice worked, thanks mike. oh notice my screen name of mc1 bean, now you know, I know what I am talking about :)
1helpful
This morning when my wife went to make coffee. The clean light came on. we couldn't get it to shut off. She went through the clean cycle.The light came back on again. What should we do ?? Mr. Coffee...
I know this sounds like a pain but it takes a while to get that silly light to stop.
If you have problems call the 1-800 number below.
Decalcifying your MR. COFFEE® Coffeemaker Minerals (calcium/limestone) found
in water will leave deposits in your coffeemaker and affect its performance. It's
recommended that you regularly remove these deposits using MR. COFFEE® Cleaner
or vinegar. MR. COFFEE® Cleaner is available at many retail stores or by calling the MR.
COFFEE® Consumer Service Department at 1-800-MR COFFEE (1-800-672-6333).
1. Follow package instructions to prepare one batch of MR. COFFEE® Cleaner. Pour the
mixture into the water reservoir. Before decalcifying, remove the water filtration disk
from the machine.
NOTE: 4 cups or 20 fl. oz. of undiluted, white household vinegar may be used as a
substitute for the cleaner.
2. Place an empty MR. COFFEE® 10-12 cup basket-style paper filter
or MR. COFFEE® permanent filter into the filter basket and slide
the brew basket in place.
3. Place the empty decanter back in the unit.
4. Press the CLEAN button until the CLEAN indicator light turns on
(Figure 9). For your convenience the cleaning cycle is automatic.
The entire cycle will take 45-60 minutes to complete.
During the cleaning your coffeemaker will:
a. Slow brew approx. 3 cups of cleaning solution.
b. Pause for 30 minutes (the CLEAN light will remain on to alert
you that the process is active).
c. After 30 minutes, your coffeemaker will brew the remainder of the cleaning
solution.
d. When complete, the CLEAN light will turn off and your coffeemaker will turn off.
5. Discard the cleaning solution and rinse the decanter thoroughly with clean water.
6. Fill the water reservoir with clean, fresh water.
7. Place the empty decanter back on the coffeemaker.
8. Remove and discard the paper filter used during the cleaning cycle. If a Mr. Coffee®
permanent filter was used during cleaning, remove it and rinse it thoroughly before
replacing it in the filter basket.
9. Begin brewing and allow the full brew cycle to complete.
10. Repeat steps 5 through 9 one more time.
Farberware superfast coffeemaker--how to i stop coffee grains getting into the brewed coffee?
Use a paper filter.
Place the filter under the coffee to be brewed. That will let the coffee through without the grinds.
We are trying to set up the hamiliton beach brew station 6 cup but do not have the manual. can you walk me threw it please?
Sure Thing :)
1) Open the lid
2) Take out the filter basket.
3) Take out the Coffee Tank and fill it with water to the appropriate mark at the back of it. (Should be a stepped type marker)
4) Pour the water from the Coffee Tank into the Water Reservoir in the coffee maker it's self. (This should be on the left side of the metal warming plate.
5) Place the Coffee Tank back on the brew station.
6) Place the Filter Basket back in the coffee maker
7) Add a coffee Filter and 5 Tablespoons of coffee
8) Close the lid
9) Press the Brew/Start button (The top left one)
15 yr-old GE electric oven takes over an hour to preheat to 450
After jiggling the lower burn element the oven heated up in the normal time. Perhaps a connection had come loose.
I purchased a sunbeam coffeemaker in June from Zellars. I didn't start using it until the first week in September. I noticed that it dripped from the coffee grinds holder even when it had finished brewing....
Contact sunbean customer service. Look on the web for contact numbers. Explain your problem and tell them you have the reciept and have been contacting Zellars but have got no response. So you decided to contact them directly. Almost all the time they will honor your problem.
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
