Question about Janome 8080 Computerized Sewing Machine
Code is 5P and I can not change this, I press the straight stitch button and nothing happens, it will not sew
  • 20 Answers
This means the bobbin winder is still engaged.
Posted on Jan 27, 2012
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: stitch
I will try it . thank you so much.
Posted on Jan 27, 2008
Anonymous
  • 3 Answers
SOURCE: Changing stitches
You probably have not adjusted you stitch width and length.
Also a manual for this machine is currently being sold on Ebay for $4+. Probably would be a good investment for you.
Posted on Mar 29, 2008
SewTechWayne
SewTechWayne
  • 186 Answers
SOURCE: The Reverse stitch button
The feed mechanism needs to be oiled. Take off the bottom cover and look for any place where two parts move against each other. Some binds can be very difficult to remove. Try spraying everything with a light weight oil (I like Tri-Flow) and let them soak over night. Then manually try to move the feed dogs with your hand. Hopefully it will break loose.
Posted on Jan 30, 2009
alicantecoli
Colin Stickland
  • 22485 Answers
SOURCE: I have a Memory Craft 8000. The computer screen
the mechanism is worn that makes the needle head move in a zig zag fashion ,need to be taken to a repair man to have the worn parts renewed
Posted on Oct 06, 2010
Singer quantum will not turn on
Have you looked at your manual? I think that you would have to pick a stitch pattern, ie. straight, zigzag. Then width and length for the machine stitch. Now, press on the foot pedal.
Dec 18, 2017 | Singer Sewing Machines
Stuck on 5P
The led light shows 5P or SP and it is stuck there I can't - Fixya
www.fixya.com/.../t25319454-led_light_shows_5p_or_sp_stuck_change
Dec 12, 2014 - the led light shows 5P or SP and it is stuck there I can't change it and the ... Question about Janome 8080 Computerized Sewing Machine.
How to Fix a Thread Jam ' Sewing Machine - YouTube
? 2:03
www.youtube.com/watch?v=TT8qvyb39O4
Sep 7, 2013 - Uploaded by Howcast
Top Rated Products for Every Sewing Project: Singer BeginnersSewing Kit: ... I've gotten longer threads ...
Oct 21, 2015 | Sewing Machines
How do I fix my kenmore sewing machine. Model # 385. 1960180
Consult your manual, the Troubleshooting section. It should explain what the Code 5P means and how to correct it.
Aug 11, 2015 | Kenmore Sewing Machines
How do you change the default stitch length for the straight stitch.
A setting change while you are sewing should not happen. Sounds like you will have to take your machine in for service.
Apr 11, 2015 | Janome Memory Craft 9000 Computerized...
Why is the fabric feeder pushing the fabric toward me instead of awayfrom me?
It is sewing in reverse. Shut down, restart the machine. If this doesn't help, press the backstitch button, and see if it stuck. Try changing the stitch length dial.
If this is an electronic machine, it may need to be serviced. This happened to a embroidery machine I had, when I tried to sew straight stitching. It needed to be service as it was an electronic issue.
Oct 27, 2014 | Sewing Machines
Cant change stitch setting
check to make sure the machine is not set for bobbin winding
Apr 19, 2012 | Sewing Machines
Machine will not complete a buttonhole, keeps showing error code 6L. No error code listed in manual. Machine will only do first half of buttonhole and then shows code and stops.
I've been looking too and I found here http://sewing.patternreview.com/cgi-bin/sewingclasses/board.pl?t=18328that you need to put the bar behind the needle threader down. I think they call it a button hole stop? I don't know, but it worked. I didn't even know it existed. But it solved my problem. On my Kenmore it looks like a black lever and you pull it down. It tells the button-holer that you are at the end of the hole and it needs to backup. nifty, kind of.
Apr 16, 2009 | Sewing Machines
LED shows 5P or SP
take the bobbin winder post (the silver metal post on the top to the right next to the spool of thread and push it to the left toward the spool of thread. The SP means it is in Spool mode.
Oct 12, 2008 | Kenmore 19110 Computerized Sewing Machine
How do I change the stiches?
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
Mar 07, 2008 | White Sewing 1418 Mechanical Sewing...
Sewing machine straight stitch is not straight
It sounds like it is making a blind stitch, does it look something like this? -----v-----v-----v-----v-----v If so it might be on the blind stitch setting instead of the straight stitch! ;-)
Oct 11, 2007 | Sewing Machines
Janome 8080 Computerized Sewing Machine Logo
172 people viewed this question
Top Janome Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Thomas F. Schneider
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
