Question about Epson - PowerLite S1+ Multimedia Projector
We have an Epson Powelite projector mounted in a classroom and just recently it is projecting everything with a purple tint to it. Before that the colors were not as vivid as when we first installed it. Any suggestions.
ecclestb
Could be as simple as a tarnished pin on the signal input connector. Remove and replace signal [vga] connector at projector end and source end. That may do it. This has worked for me on numerous occasions at our school district. I'm their tech.
Posted on Feb 23, 2015
Anonymous
    New Friend:
  • 24 Answers
An image is produced in these projectors by passing color through three different LCD panels. One is a Red, one a blue, and the last one a purple. It sounds like the green panel is damaged. The only way to tell is to take it to an Epson authorized service center.
Posted on Mar 09, 2011
Epson 822+ Projector still dim after replacing bulb
I'm not familiar with your specific model, but are the units LCD or DLP? What I've seen in LCD projectors used in schools, museums, etc. that are left-on for several hours per-day, is that the UV filters in the optical blocks will fail. They usually change to an amber-brown color and block most of the light. It's the equivalent to putting sunglasses on. Do the units also exhibit a greenish-yellow tint instead of proper color?
My Epson EX7200 was purchased May 3rd and until recently has been working well. Now the projection has a blue tint to it
I would recommend contacting Epson support. Your projector should have a 1-yr manufacture warranty, and they can verify that once you give them the serial number of the projector. In the meantime check your computer cable (if that's the input you're using) for bent pins. You can also apply the "Reset All" option, which restore all the settings back to factory default. However, in some cases the blue LCD panel might have gone out also.
CPX 201 - everything projects with a purple tint.
check your cable connection attached to your computer...
2helpful
Why is my projector suddenly projecting pink?
Is it entirely pink or does everything have a purplish tint? Check the settings. If you are connected using component or VGA, make sure that the unit is set to RGB rather than YPrPb.
Update this with what you find.
Thanks,
Dan
The projector is projecting everything in a purple tint.
The projector is projecting everything in a purple Does it need a new lamp
11helpful
2answers
Projected image has pinkish purple tint
Simply pushing the Help Button, and then selecting, Problem with the Image, and then setting the Computer to Auto fixed the problem! Thanks!
The color on my Epson Powerlite S3 powerpoint projector is very purple; not the true colors at all. I have tried adjusting it using the color, tint, brightness, etc. adjustments but it never gets to the...
Two possible solutions:
1) The video mode is set to Component/RGB instead of VGA.
2) The cable you have may have a break inside of it.
Let me know if you find anything.
-Jeff
Everything is purple!
Hi there
Try using a different cable , should do the trick
1helpful
Color problems
Your BLUE LCD Panel is blown, this is a $400 repair.
Purple and green and shaking....
Hi guys
You will have to replace the LCD's .
Must warn you that it is very expensive
Epson - PowerLite S1+ Multimedia Projector Logo
Top Epson Office Equipment & Supplies Experts
Ekse
Randy Prevost
Randy Prevost
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
