Hi i set up the speaker wireing but i cant get any sound but when i put the power on i hear the sub woffer go on. is ther any reset button on this unit? i had video now i dont. charlie i tried playing arond with the tv setting no good its a samsung plasma. its got to be something simple charlie
You'll only get a subwoofer signal if your cable/satellite box or other source has a dedicated SUB output on a coaxial cable. If it does plug that into the 5.1 SUB input and then as the pic states.
If there is power to the woofer then a signal input must power the woofer to work. So feed a test signal or a audio siignal from a DVD and if there is no output then the AMPLIFIER section had faults.
Unless the sealed unit is opened it cannot be tested to confirm if the output , the input to the AMP or the power supply has failed.
Check if there is power to the output section to confirm.
if you dont have a crossover you will not get the best performance out of your sub. you need to seperate the frequencies and send only the lows to the sub woffers.
Check to make sure your amplifier is set to LOW PASS FILTER, not HIGH PASS. Make sure your settings on your head unit are set for full range, meaning 0 balance/fader.
Could be Faulty RCA wires (they bring the sound from the radio to the amp) or a bad ground (the larger black wire coming out of the amp) This is under warrranty and you should not have to worry about it... bring it back, they make fix..
I was face the same problem 2 year's ago.This problem occur when you move the speaker's here and there.at that time speaker's wire diconnected in inside...please check the whole wire by electricians for where exactly it is disconnected...
