InFocus IN24 Multimedia Projector Logo
Posted on Mar 08, 2011
Hi I work as IT at Santa Monica schools , I'm having an issue with one of the IN24 proj. it showing wrong colors, green is yellow red is violet etc the lamp has 286 hrs used any sugestion?
Anonymous
Level 1:
New Friend:
  • Contributor 26 Answers
  • Posted on Mar 09, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
26
Questions
0
Helped
6299
Points
67
Looks like damaged cable or bad connection
or else its faulty
Colourcode. resistersr512andr514. forPacificsubwooferhcs101circuitboard
Resistor color code is as follows:
Black-0/.0
Brown-1/0
Red-2/00
Orange-3/000
Yellow-4/0000
Green-5/00000
Blue-6/000000
Violet-7/0000000
Grey-8/00000000
White-9/000000000
The first and second color corresponds to the numbers .0-9
The 3rd color corresponds to the zero(s).
So, 512 would be: Green/Brown/Red (5100 ohms)
and 514 would be: Green/Brown/Yellow (510000 Ohms).
Stereo wires by color
Red 12v permanent live.
Yellow 12v switched live.
Black ground earth.
blue/white amp or power antenna
yellow/black mute
speakers
white front left (-)
white/Black front left (+)
Grey front right (-)
Grey/Black front right (+)
Green rear left (-)
Green/Black rear left (+)
Violet rear right (-)
Violet/Black rear right (+)
3helpful
I am installing a CD player in a 2004 Nissan Sentra and I need to find the wiring diagram to show me how. Can you help?
see connection colors below and let me know if you have questions.
2004 Nissan Sentra wire colors aftermarket radio wire colors
Car Radio Constant 12v+ Wire: Pink, yellow
Car Radio Switched 12v+ Wire: Blue, red
Car Radio Ground Wire: Gray, black
Car Radio Illumination Wire: Red/Green, N/A (tape off factory wire)
Car Stereo Dimmer Wire: Red/Yellow, N/A (tape off factory wire)
there is no factory amplifier wire, blue (tape off radio wire)
Left Front Speaker Positive Wire (+): Pink, white
Left Front Speaker Negative Wire (-): Blue, white/black
Right Front Speaker Positive Wire (+): White, gray
Right Front Speaker Negative Wire (-): Black, gray/black
Left Rear Speaker Positive Wire (+): Light Green, green
Left Rear Speaker Negative Wire (-): Violet, green/black
Right Rear Speaker Positive Wire (+): Blue, violet
Right Rear Speaker Negative Wire (-): Pink, violet/black
Pioneer KEH-8031ZT connection diagram of power and speakers
There are two kinds of pioneer color codes:
pre 1999
P o w e r Memory (+12v Constant) Orange Ignition (+12v Switched) Red Ground (-) Black Illumination Yellow Phone Mute Yellow/Black Power Antenna Blue S p e a k e r s Right Front (+) Gray Right Front (-) Gray/Black Left Front (+) Green Left Front (-) Green/Black Right Rear (+) Gray/Red Right Rear (-) Black/Gray Left Rear (+) Green/Red Left Rear (-) Black/Green
and 2000 or newer
Memory / Constant 12V(+) Yellow Switch / Accessory Red Ground Black Illumination Orange/White Antenna Remote Blue Amp Remote Blue/White Left Front (+) White Left Front (-) White/Black Right Front (+) Grey Right Front (-) Grey/Black Left Rear (+) Green Left Rear (-) Green/Black Right Rear (+) Violet Right Rear (-) Violet/Black headunitwh.gif
Ive got the red power wire hook up and the yellow 12v hot all the time but dont now what color the ground wire is or the speekers are
Your ground wire is going to be black. Your normal wire colors are violet and violet/black, green and green/black, white and white/black, last but not least you have grey and grey/black. Those are your speaker wires. Solid blue is usually to power your antenna, and blue/white is for your amp turn on lead. Those two wires are approximately .5mV of power, and you can actually use either one to turn an amp on. Speakers: normally your solid color is positive, while the black stripe is your negative. As for which one goes to which speaker, left front is white, right front is gray, left rear is green, and right rear is violet. Hope this helps.
I need the color code for phone cables. 25 pair up to 1800 pair. I need to splice it.
white/blue
white orange
white green
white brown
white slate
red blue
red orange
red green
red brown
red slate
black blue
black orange
black green
black brown
black slate
yellow blue
yellow orange
yellow green
yellow brown
yellow slate
violet blue
violet orange
violet green
violet brown
violet slate
**Keep all pairs together and you should be fine***
11helpful
I need wire color codes for a 2009 Ford ranger basic radio. Installing an aftermarket stereo.
I took my time to find this for u please show your thanks with a "FIXYA" rating.
2009 Ford Ranger Car Stereo Installation Guide
Car Radio Battery Constant 12v+ Wire: Violet/Red
Car Radio Accessory Switched 12v+ Wire: White/Red
Car Radio Ground Wire: Black/Yellow
Car Radio Illumination Wire: Blue/White
Car Stereo Dimmer Wire: Green/Red
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White
Left Front Speaker Negative Wire (-): White/Brown
Right Front Speaker Positive Wire (+): White/Violet
Right Front Speaker Negative Wire (-): White/Orange
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Orange
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Brown/White
Right Rear Speaker Negative Wire (-): Brown/Blue
1helpful
I hav a 95 berrta and im tying to put a head unit
Hello chrisuftring,
Here's a link to the wiring color code for the '95 Chevy Beretta.
You'll need to match the function of each wire from your head unit and the color code for that would be in your manual. Most aftermarket units are somewhat standard as far as power, accessory, ground, and speaker connections are concerned. But the wiring colors may be different for such leads as remote, power antenna, illumination, dimmer, and muting.
An Alpine head unit has the following wiring colors:
Blue - Power Antenna
Blue/White - Remote
Pink/Black - Audio Interrupt (muting)
Orange - Illumination
Red- Switched 12V+
Yellow - Constant 12V+
Black - Ground
Gray - RF Speaker (+)
Gray/Black - RF Speaker (-)
White - LF Speaker (+)
White/Black LF Speaker (-)
Violet - RR Speaker (+)
Violet/Black RR Speaker (-)
Green - LR Speaker (+)
Green/Black - LR Speaker (-)
With this head unit, you would wire Yellow to Orange, Red to Yellow, Black to Black, Orange to Gray, Blue to Pink, Gray to Light Green, Gray/Black to Dark Green, White to Tan, White/Black to Gray, Violet to Dark Blue, Violet/Black to Light Blue, Green to Brown, and Green/Black to Yellow.
Note that there are 2 "yellow" wires in your vehicle color code. You'll have to test them to determine which one is the accessory wire and which one goes to the left rear speaker. Using a 12V "test light" is the simplest. Connect one side of the light to ground. With the ignition ON probe the yellow wires. One of them should light the tester, the other one won't. Verify that the light goes out when the ignition is OFF and your have separated the redundant "yellows". The one that lit the tester is your 12V+ switched wire and the other one goes to the left rear speaker.
Hope this helps.
2helpful
Suburu radio wire harness. trying to match up with a new soni deck
Hello uze7, Here is the wiring match up for a 2009 Subaru Forester using the Metra 70-7552 wiring harness: NOTE: The actual harness will be listed as a Nissan harness, but has been used by Subaru since 2007. Also, I'm assuming that your Sony deck uses the standard color code. If not, you should have a manual that lists the function along with the colors. Match the wiring by function, not by color (although the colors may be the same). 2009 Subaru Forester Radio Wiring Color Code: Battery BLUE/RED (+) RADIO HARNESS Accessory YELLOW/RED (+) RADIO HARNESS Ground BLACK (-) RADIO HARNESS Illumination VIOLET (+) RADIO HARNESS Dimmer BLACK/WHITE (-) RADIO HARNESS Power Antenna YELLOW/BLACK (+) RADIO HARNESS LF Speaker (+) BROWN LF Speaker (-) BROWN/WHITE RF Speaker (+) BLUE/WHITE RF Speaker (-) BLUE/YELLOW LR Speaker (+) WHITE/BLACK LR Speaker (-) RED/YELLOW RR Speaker (+) GRAY RR Speaker (-) GRAY/RED Metra Harness: Yellow ? 12V Constant Red ? 12V Accessory Black - Ground Orange ? Dash Light Dimmer/Illumination Green ? Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) White ? Left Front Speaker (+) White/Black ? Left Front Speaker (-) Purple ? Right Rear Speaker (+) Purple/Black - Right Rear Speaker (-) Gray ? Right Front Speaker (+) Gray/Black - Right Front Speaker (-) Standard CEA Color Code: Blue - Power Antenna Blue/White - Remote Turn-on Pink/Black - Audio Interrupt In (Phone) Orange - Illumination Red - Ignition (Switched 12V) Yellow - Battery (Constant 12V) Black - Ground Gray - Right Front Speaker (+) Gray/Black - Right Front Speaker (-) White - Left Front Speaker (+) White/Black -Left Front Speaker (-) Violet - Right Rear Speaker (+) Violet/Black - Right Rear Speaker (-) Green - Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) Hope this helps.
Top InFocus Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
