Sylvania SDVD8732 Player Logo
Posted on Mar 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have lost the power adaptor for my Sylvania SDVD8732 player-where can I purchase a new one and how much will it cost
Anonymous
Level 2:
New Friend:
  • Expert 41 Answers
  • Posted on Mar 08, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
41
Questions
0
Helped
5783
Points
120
Sylvania SMP2012. Apparently fully charged. Why doesn't it turn on?
On Off switch is the slide button on the side The switch may be faulty. You don't normally need it switched on to use USB, as the computer is supplying the power. This says it needs to be on for charging, that is odd!
Battery
3. Remarks (Additional information for Adaptor purchase)
2.1 Make sure the power switch is on to charge, or the player
could not be charged properly. The LED light 2 and LED light 1
are on when the player is charging, the light 1 will be off when
the battery is full
3.1 The adaptor must be conformed to following standard
the battery is full
2.2 Disconnect the player and charger if you want to stop charging
3.1.2 Output: 5.2V 0.2V
3.1.3 Max.: 350mA
3.1.4 4 pins adaptor
When connecting to the computer via USB, it WON'T be recognised as such, but it you open Windows File Explorer, you will see it as a Volume in the left hand side pane. Drag music to a folder and drop music in from there.
http://portablemedia.manualsonline.com/manuals/mfg/osram_sylvania/smp2012.html
I just bought this DVD player brand new and it won't turn on
return for replacement! if this is new you should have no problem turning it on!
SDVD8732 7-Inch Dual Screen Portable DVD Player not displaying picture on screen
On one or both? Take a flash light and look close at the screen while playing something. If you can see the picture on the screens then it is a back light problem. They are not easy to repair.
Missing the power cord
Of course you can, or go to your local electronics supply store and see if they have one that will work.
The dvd in my sylvania dvd player keeps getting stuck, can I fix it?
dvd players are a touchy thing and when they start doing this its time to get a new one or have it repaired.
The laser light is not lit
Replace the strip wire that connects laser pickup unit to main baord at first. If do not help, repalce the laser pickup unit.
Sylvania SDVD8732 Dual Screen DVD Player - SD/SDHC Cards
AS long as its a newer SD card you will be fine. Stick with name brands like Kingston, Samsung HP etc. Stay way from cheaper cards as they wont work as well.
1helpful
Quit working
Remove the main battery and power on, if no! check power supply that it puts out the correct voltage, if okay! the main board would need to be replaced, not cost effective to repair, cheaper to replace.
1helpful
Dvd will not load.
Hello
I would open it up and use some alcohol on a qtip and clean the laser. Small piece of round glass under the disc
If that doesn't work I would replace it, most likely coincidence on it breaking although you can't rule out being dropped or similar. However your dvd player parts are hard to get and rarely worth the time to fix they have gotten so cheap.. Thanks!
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
