Whirlpool 24 in. GU1200XT Built-in Dishwasher Logo
Question about Whirlpool 24 in. GU1200XT Built-in Dishwasher
I have a whirlpool GU1200 dishwasher. There is a screen in the pump inlet which is located in a sump below the lower spray arm. It is getting plugged and needs to be cleaned, but I can't get the lower arm off. How do you remove the arm and shield to expose the screws to open the sump?
  • Anonymous Mar 08, 2011
    Straight away anser is that it's a LH trhead. Thanks! I got it off.
Anonymous
    Guru:
  • 262 Answers
Hello....My name is Keith.....Please give me one moment while I bring up the parts drawings, and then I will start to address the issue.
Thank You....
Posted on Mar 08, 2011
1helpful
Dish washer won't wash dishes.
Remove the screen below the spray arm and clean the sump.
Replace the impeller kit on the motor shaft.
Clean debris out of the holes in the spray arm.
Whirlpool Dishwasher Model GU1200XT
Check the upper spray arm for debris plugging the spray holes, if clean then pull off lower spray arm and filter screen, and clean and remove any debris found in the sump, check the disposal blades as well. You will need a torx style screwdriver to remove the sump screen on this unit. You can buy a set for under $10 at your local hardware store.
Dishwasher does not clean items on top shelf.
Check the upper spray arm holes for debris that may be plugging up the spray arm. If clean remove the lower spray arm and filter screen and clean out any debris in the sump.
4answers
Dishwasher spray arms don't spin & spray water
Check that the water pumped on arms has enough pressure.
2helpful
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
1. Remove lower spray arm and rear water supply tube to upper spray arm.
2. Remove torx screws that secure the sump cover.
3. Remove primary filter
4. Remove food chopper cover to expose the chopper assembly. Inspect for breakage or blockage.
If you need further assistance, let me know
Regards,
reg501
Whirlpool Quiet GU2300XTLS2
Check water level:
Remove lower spray arm and rear water supply tube to upper spray arm. Remove torx screws that secure the sump cover. Remove the rounded cover on the left side to expose the chopper assembly. Inspect for breakage of blockage. There may be an additional plastic screen to remove first.
3helpful
Whirlpool quiet wash plus
I assume you are having spray issues, or a grinding noise. If odor is your issue, go to the bottom of the message.
For the dishwasher pictured above, Open the door. Remove the lower rack.
Push in the tabs holding the upper basket rail end caps and slide the caps up and out. Remove the upper rack. Clean the holes in the upper (or middle) spray arm.
Hold the lower spray arm still and rotote the thumb tab clockwise. Remove the lower spray arm. Clean the holes in the lower spray arm.
Use a small flat screwdriver to release the tabs holding the upper spray tube from the dishwasher inner wall and ceiling. Rotate the spray tube to the right and remove the tube.
Using a # 20 Torx bit, remove the (about 10) small screws holding in the top of the sump assembly. Remove the top section with the fingers all around it.
Using a # 15 Torx bit, remove the screw holding the round cover over the pump suction. Remove the cover (grab the tab sticking off the corner with a pliers and pull up.)
Anything stuck in the sump will now be visible. If the screen is completely clogged up, then the blade isn't wiping the screen clean. In this case, the screen should be replaced.
The screen is removable, but difficult to re-install. If you need to re-place it, put an open end wrench between the screen and the rotating blade to hold the spring compressed. Also, notice the screen isn't round. The flat edges fit only in the slots they came from.
If it's odor or white powder you want to clean out, use a dishwasher cleaning product such as Dishwasher Magic.
I tell every dishwasher customer: "You do not need to rinse your dishes before washing. But you do need to scrape them off."
2answers
Water not spraying hard enough
Check water level:
6helpful
Small plastic top and mid spray arm do not turn, bottom does
decrete, you want to get down to the chopper and screen. If the screen is plugged up with gunk there won't be enough pressure to reach the top spray arms. Check out the posted pics. Remove the lower spray arm. Rotate the rear feed arm to the right until it unsnaps from the tube going up the back. See the 4 torq screws holding the filter on. Remove them. Lift the filter up. Now you will see the chopper inlet cover. 1 torq screw holding it in. Lift it up and there's the chopper and screen. Catriver..post back
Top Whirlpool Dishwashers Experts
Mike
Marvin
Marvin
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
