Question about Home
My partner didn't have any idea of fixing a shower door so it can close properly so what he has done is grinded the metal part of the shower frame so the door does not hit it when it close. Now because he has grinded the metal it is now a safety hazard if people steps on it. I need to replace the bottom part of the frame, is it possible to just buy the bottom part of the frame and what do you call it or do I need to purchase a whole frame for the door?
Posted by think3rrr on
woobie dog
    President:
  • 1,273 Answers
Hello, W/D here.
You can file and sand the burrs smooth and eliminate the hazard somewhat or you can probably buy a replacement threshold from a local shower builder (really, they're out there). Look in the book for custom shower/bath builders, and they'll have parts. The hardware stores rarely have shower thresholds, but you could look; you may get lucky. Usually, they would rather sell you a kit. We had a replacement shower door built with side panels, and it was pretty easy. If you want a replacement door frame, you can call it that, and they'll know what you mean. If you ask, they'll probably come out and take a look for free, and estimate the cost for them to do it. When we were going to replace our shower door and panels, the cost of them doing it vs. me getting the proper parts and doing it myself were so close that we just let them do it. Sometimes it just works out that way. They measured, built and installed it in several days. Your "repairs" will take much less time.
Best regards, --W/D--
Posted on Mar 08, 2011
Testimonial: "Very helpful for someone who is in a panic mode and having no idea... Thank You!"
  • think3rrr Mar 08, 2011
    Hi W/D,
    Thank you for the advice, I'll look into finding a replacement threshold if they do sell it! The thing is I have a friend who is a handy man who had a look at it and has taken the bottom part of the metal frame (I think my shower door is called semi-frameless or inline panel type). We have been looking for a replacement but can't find it in any Bunnings Hardware stores (Sydney Australia Hardware store) so I'm dreading to have to purchase a whole set of shower frame... What to do?
    Worried,
    Think3rrr
Why will the door not stay closed ?
it could be the latch frame and casing but if no one has recently put a crowbar in to door lock to force your door open - i would say its an eletrical fault check the sensor on the door frame and on the door and make sure they line up while the door is closed and if thats the case i would say you have a fault with the hall sensor or ghosts haha just kidding
May 27, 2014 | Bosch SHE3AR55UC Builtin Dishwasher
Roll up garage doors window replacement
If in the g.door frame, it should be easy to put it back with glue and caulk making sure the finishing matches with other panels. You may need a helper.
Jun 21, 2013 | Building Materials
2005 Ford Explorer is making a grinding noise
I had some issues with my 2005 explorer left rear. It was making a creepy old door sound at low speeds and then a high pitched whisel at high speeds. That turned out to be a broken wheel bearing and had it replaced. Note each wheel has two wheel bearings. After that a new noise developed that sounded like metal scraping/ grinding metal. It end up being the brake dust cover got bent when they replaced the bearing and it was rubbing something, the fix for that was bending it so it didn't rub. I hope this helps.
Sep 03, 2012 | 2005 Ford Explorer
Freezer door does not have the vacuum suction that it did have
Check the door is square to the frame and no shelves are sticking out stopping the door from closing properly. The seal should be magnetic and stick to the frame quite well.Check no metal strips have come off so the magnetic seal isn't attaching to the frame
May 20, 2012 | Frigidaire 20 cu. ft. / 566 liter Upright...
My KRUPS FBC2 glass door hinge is broken. We use a pan to keep door in place when using it so it doesn't fall down. Any ideas on how to fix it will be appreciated. I'm pretty handy with things but I just...
I just fixed the problem with my Krups FBC-212. The door would not stay closed because the spring that keeps it in the closed position was broken. I ordered another from one of the small appliances parts sites (about $7 plus shipping) and that fixed it. I will describe how to do it and how to avoid the mistake that made it much harder and longer than it should have.
Remove the black screws at the back side, the ones holding the external black metal case to the silver chassis. There are 9 of these on my oven.
Also remove the 3 screws holding the left-side foot on.
Now you can probably slide the metal case (previously held on by the 9 screws) out from under the black metal front frame on the left side, thereby exposing the broken spring.
If you cannot get it out from under the lip of the front frame, you can take off the right-hand foot, and if that is not enough, you can remove THREE of the 4 black screws just inside the door holding the front frame to the chassis. Do NOT remove the lower left one next to where the flat door hinge piece goes into oven (which was my mistake) because that screw holds a critical black plastic piece in place.
By now you will be able to slide the black case that covers the sides and top backward and outward enough to expose the broken spring. It will be obvious how to attach the new one.
Aug 28, 2010 | Krups FBC2 1600 Watts Toaster Oven with...
I have a domestic built in dishwasher but the door does not shut, the white bit at the top does not close the door,
I think when you say the "bit at the top" you are referring to the metal tab that engages into the door interlock switch mounted in the door frame. If so it is and easy fix.
The metal tab engages the door switch, this is the same switch that is actuated by moving the handle on the door. It tells the machine that the door is closed and it is OK to start. The tab can become misaligned or bent over time and will not engage properly.
To fix this the easy way is to simply bend the metal tab so as it engages properly. You will need to fiddle with it to get it to the correct position but it will work when you get it there.
The only other door jam that can happen is the springs the support the door become jammed. This you will know right away if the door just falls to the floor when opened. The springs can jam in the door hinge and stop it closing. You would pull the machine out and reconnect the springs. But from what you say this is not the problem.
I hope this help you, please take the time to rate this answer.
Mar 19, 2010 | Dishwashers
I have a 2005 Chevy Malibu and the drivers side door does not seal properly at the top of the door and the elements leak in. How do I fix this?
What sometimes happens is something gets caught in the door when closing and bends the window frame out. If your hinges and latches are not worn out and the door opens and closes properly this solution should work for you.
Place a block of wood between the inside bottom of your door and the rocker in a solid place. this will allow you to push gently on the frame around your window (roll the window down). Try a little at a time and open and close the door as you do this.
Be careful, they are not as strong as you think and going too far may create a metal kink.
Nov 15, 2009 | 2005 Chevrolet Malibu
Spartan brand curved glass shower door installation info needed.
curved cut glass will not always be the exact dimensions though they may look identical there should be several set screws on both the door glass frame and the shower glass frame that can be loosened and reset to make the door fit and close and open more properly without seeing the showwer itself i can not tell you exactly where they are but they should be either visible or behind a facade piece of metal frame
Aug 27, 2009 | Sterling Plumbing Sterling& By-Pass Shower...
I have a new frameless glass shower and every time I open or close the door in iether direction there is a loud ''clicking'' noise that sounds like a spring is breaking. Any Ideas?
It sounds like you have something caught up in the hinges, or in between the door and the opening. I would have whoever installed it come back and fix it. As a general contractor I would not be happy with myself if I had installed it and would like the opportunity to redeem myself if it was not done correctly.
Jul 30, 2009 | Home
Frameless shower door sticking to the opposite wall when closing
you can fix this problem by loostening the clamp screw and putting locktite sealer(you can purchase locktite from hd or lowes locktite is not the only product you can call a glass supplier and as for recommendation) Be sure to read the directions on the tube I use it to seal joints on refrigeration threaded parts. Make sure it will adhere to glass and metal also review the clean up solvent when you do this place a wood wedge at the bottom of the glass dooor and the threashold to support he weight until the sealer driese
Steps
1 Place wood wedge/block under door where non hinged side meets wall
2 losten top hinge(inspect bottom hinge to make sure it is snug and the glass dor is all the way into the hinge
3 You may have to remove the top hinge completely to get enough of the locktite on the metal and glass place the locktite on the hinge flat plate and the glass
4 recheck gap where door meets wall( I sometimes use paint stirs(wood) as shims to keep space between door and wall consistent
5 tighten top inge screws( you can put locktite on the screw threas also
6 Clean excess locktite and wait suggested time by instructions on tube
Good Luck!
Dec 31, 2008 | Home
Home Logo
120 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
