Error 0xc05d1281 in HP photosmart C7280 and the printer cant print
Posted by mariad_espin on
  • 7,733 Answers
HP c8180 error code oxc05d1281
http://h30434.www3.hp.com/t5/Other-Printing-Questions/0xc05d1281-Error-code-for-Photosmart-C8180/td-p/1212853
Apr 10, 2015 | HP Office Equipment & Supplies
hi............
pls click here for solution
thank you.........
Jul 29, 2011 | HP Photosmart C7280 Printer
HP C7280 printer: "Pump motor stalled" error
This means there's a failure in your printer's pump motor.
If you are still under warranty, contact HP's Customer Service here : http://welcome.hp.com/country/us/en/wwcontact_us.html
If not, you can try your local computer store for a check-up but they'll probably suggest a new printer.
Hope this helped.
Please rate :)
Mar 04, 2011 | HP Photosmart C7280 Printer
Display says error 0xc05d1281
The "Ink System Failure" error is causes by air in the ink feed tubes. We have a step by step guide purging the air from the feed tubes posted on our web site. Go to our site at: www.ccl-la.com , click on the printer repair link and then the HP link. Follow the steps and you should be back printing in no time at all.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 03, 2010 | HP Photosmart C5180 All-In-One InkJet...
0xc05d1281 HP-C7280 Ink System Failed -- tried clearing the error status still same problem, also noise from the print head sounds like plastic gears sliping, print head moves back and forth gears slip and...
printer did not tell about empty cartrigde it just showed that the black was low but not empty -- decided to replace the cartridge early and that ficed the problem!! ?????
Oct 19, 2009 | HP Photosmart C7280 Laser Printer
How to take apart HP photosmart D7360
My HP D7360 won't print. Its says the "ink system has failed. Unable to print. Refer to printer Doc. Error: 0xc05d1281" Now, I lifted the printer up and it sounds like a screw bouncing around on the inside. How do I take this thing apart to find the screw and put it back in it's place???
Aug 27, 2009 | HP Photosmart D7360 All-In-One InkJet...
Unable to add a functioning (second) printer, for greyscale.
Clicked on Start/Control Panel/PrinterI. Clicked Add a printer. Obtained (Copy 1) of my HP Photosmart C7280 all-in-one printer. Right clicked on (Copy 1)/properties. Opened Ports tab. Saw comment "Print to the following Ports. Documents will print to the first free checked port." A listed USB Virtual printer port, showed three printers -- my first printer, my copy 1 (& my fax printer) -- was unchecked. I placed a checkmark in this Port box. Both the original printer, and my copy 1 printer are printing just fine. *I have not checked to verify that my fax is functional.
I did rename the original "color". I renamed Copy 1 as "grayscale", and --under printer preferences, checked, under "color options", to print in greyscale.
Mar 30, 2009 | HP Photosmart C3180 All-In-One InkJet...
Ink failure
put ink cartridges in the printer
Jul 20, 2017 | HP Photosmart C7280 Laser Printer
594 people viewed this question
Ekse
Marvin
Marvin
